HPOV Device Profiles
Problem this snippet solves:
HPOV NNMi provides a method to populate your device profiles using simple import and export commands. The file provided is an export of the current F5 device values. You can import the file into your system using the OV command nnmconfigimport.ovpl.
Code :
nnmconfigimport.ovpl -u myadminusername -p myadminpassword -f F5_devices_Jan09.xml
Published Mar 12, 2015
