The_Bhattman
Altostratus
Altostratus
Problem this snippet solves:
iRule was created to allow ADC to mimic the FTP Proxy connectivity such as the ones found on Bluecoats and Cisco Ironports.
How to use this snippet:
How it works
FTP client (CuteFTP/WS_FTP, etc) is configured to explicitly point to a FTP Proxy VIP containing the iRule below on port 21 and utilize the authentication type USER@.
Special Considerations
If the ftp site is remote from the F5 ADC then consider Autosnat either in the iRule OR configured at the VIP level.
Limitations
Since the Remote FTP server is connected on demand, it doesn't perform any healthchecks.
Additional Notes
Feel free to make improvements such as adding the ability to use hostnames, which will involve lookups. This might also require https://support.f5.com/kb/en-us/solutions/public/8000/400/sol8437.html to make the hostname resolution to work.
If you need code that works in v9.3.x then please go to the following link http://devcentral.f5.com/wiki/default.aspx/iRules/FTP_Proxy_LITE.html
Code :
when CLIENT_ACCEPTED {
TCP::respond "220 Welcome to the F5 FTP Proxy v10\r\n"
#log local0. "client accepted"
TCP::collect
when CLIENT_DATA {
set ftplogin [TCP::payload]
log local0. "login is $ftplogin"
if { $ftplogin starts_with "USER" } {
# You can set it up to use any DNS server you want.
set dnslookup "4.2.2.1"
set cuser [TCP::payload]
scan $cuser {%[^@]@%s} garbage sitename
scan $garbage %s%s cmd uid
set ips [RESOLV::lookup @$dnslookup -a $sitename]
if {$ips eq "" } {
# Input wasn't an IP address, take some default action?
reject
TCP::payload replace 0 [TCP::payload length] ""
set ftp_serv "[lindex $ips 0]"
node [lindex $ips 0] [TCP::local_port]
TCP::release
when SERVER_CONNECTED {
    TCP::collect
when SERVER_DATA {
    set serv_data [TCP::payload]
if { $serv_data contains "220" } {
TCP::respond "USER $uid\r\n"
TCP::release
Version history
Last update:
‎17-Mar-2015 14:06
Updated by:
Contributors
