DNS Monitor Using NS Lookup
Problem this snippet solves:
This monitor uses nslookup to verify an expected response from load balanced DNS servers. It accepts 2 command-line arguments: the name to be looked up, and a string found in the expected response.
NOTE: Use external monitors only when a built-in monitor won't do the trick. This example is intended to demonstrate the basic use of nslookup in an external monitor to test UDP-based name services.
How to use this snippet:
Implementation
Create a new file containing the code below on the LTM filesystem. Recommended location is /config/eav. Permissions on the file must be 700 or better, giving root rwx access to the file. 2. Create a monitor profile of type "External" with the following values:
- External Program: . . the name of the script file created in step 1
- Arguments:
- 3. Adjust the interval and timeout as appropriate for your application
Code :
#!/bin/sh # (c) Copyright 1996-2007 F5 Networks, Inc. # # This software is confidential and may contain trade secrets that are the # property of F5 Networks, Inc. No part of the software may be disclosed # to other parties without the express written consent of F5 Networks, Inc. # It is against the law to copy the software. No part of the software may # be reproduced, transmitted, or distributed in any form or by any means, # electronic or mechanical, including photocopying, recording, or information # storage and retrieval systems, for any purpose without the express written # permission of F5 Networks, Inc. Our services are only available for legal # users of the program, for instance in the event that we extend our services # by offering the updating of files via the Internet. # # # these arguments supplied automatically for all external monitors: # $1 = IP (nnn.nnn.nnn.nnn notation or hostname) # $2 = port (decimal, host byte order) -- not used in this monitor, assumes default port 53 # $3 = name to be looked up # $4 = string in expected response node_ip=`echo $1 | sed 's/::ffff://'` pidfile="/var/run/`basename $0`.$node_ip..$2.pid" if [ -f $pidfile ] then kill -9 `cat $pidfile` > /dev/null 2>&1 fi echo "$$" > $pidfile nslookup ${3} $node_ip 2>/dev/null | grep -qi "${4}" status=$? if [ $status -eq 0 ] then # Need to complete any cleanup activity before sending anything to STDOUT as the script is stopped then. rm -f $pidfile echo "UP" else rm -f $pidfile fi
Published Mar 12, 2015
