Delete Device (Java code sample)
Problem this snippet solves:
This Java client code sample uses Enterprise Manager's device inventory to delete a list of devices managed by the referenced Enterprise Manager.
Code :
/** * A class for testing the Management::EM::delete_devices iControl interface. */ public class ManagementEMDeleteDevices { private static int MIN_ARGS = 3; private static String USAGE = "ManagementEMDeleteDevices " + "[] ..."; private static int EM_PORT = 443; /** * The main method. * * @param args command line arguments */ public static void main(String[] args) { if (args.length < MIN_ARGS) { System.err.println("Usage: " + USAGE); System.exit(1); } String emAddress = args[0]; String emUsername = args[1]; String emPassword = args[2]; String[] deviceAddresses = new String[args.length - MIN_ARGS]; for (int i = 0; i < deviceAddresses.length; i++) { deviceAddresses[i] = args[i + MIN_ARGS]; } try { iControl.Interfaces ic = new iControl.Interfaces(); ic.initialize(emAddress, EM_PORT, emUsername, emPassword); ic.getManagementEM().delete_devices(deviceAddresses); } catch (Exception e) { System.err.println("Failed to delete devices: " + e.getMessage()); System.exit(1); } System.out.println("Device(s) deleted"); } // public static void main } // public class ManagementEMDeleteDevices
Published Mar 07, 2015
