Problem this snippet solves:
This C# client code sample uses Enterprise Manager's device inventory to delete a list of devices managed by the referenced Enterprise Manager.
Code :
using System;
using iControl;
 * A class for testing the Management::EM::delete_devices iControl interface.
class ManagementEMDeleteDevices {
    private static int MIN_ARGS = 3;
    private static string USAGE =
"ManagementEMDeleteDevices    " +
    private static int EM_PORT = 443;
     * The main method.
     * @param args command line arguments
    static void Main(string[] args)
if (args.Length < MIN_ARGS) {
    Console.WriteLine("Usage: " + USAGE);
    Environment.Exit(1);
string emAddress = args[0];
string emUsername = args[1];
string emPassword = args[2];
String[] deviceAddresses = new String[args.Length - MIN_ARGS];
for (int i = 0; i < deviceAddresses.Length; i++) {
     deviceAddresses[i] = args[i + MIN_ARGS];
try {
    Interfaces ic = new Interfaces();
    ic.initialize(emAddress, EM_PORT, emUsername, emPassword);
    ic.ManagementEM.delete_devices(deviceAddresses);
catch (Exception e) {
    Console.WriteLine("Failed to delete devices: " + e.Message);
Console.WriteLine("Device(s) deleted.");
    } // Main
} // class ManagementEMDeleteDevices
Version history
Last update:
‎07-Mar-2015 14:33
Updated by:
Contributors
