Joe_Jordan
F5 Employee
F5 Employee
Problem this snippet solves:
Checksums for F5 supported OpenStack Heat Orchestration templates
F5 Networks provides checksums for all of our supported OpenStack Heat Orchestration templates.
You can find the OpenStack Heat Orchestration templates in the dist directory on GitHub: https://github.com/F5Networks/f5-openstack-hot/tree/master/dist
For OpenStack, all of the templates themselves are located in the f5-openstack-hot-supported.tar.gz file. See the individual README files for information about individual supported templates: https://github.com/F5Networks/f5-openstack-hot/tree/master/supported/templates.
You can get a checksum for a particular template by running one of the following commands, depending on your operating system:
  • Linux: sha512sum <path_to_template>
  • Windows using CertUtil: CertUtil –hashfile <path_to_template> SHA512
You can compare the checksum produced by that command against the following list.
OpenStack Heat Orchestration Templates
Release 4.0.0
f5-openstack-hot-supported.tar.gz fc3c1bb04cb26a2ef94b45c3f5554d77e6b19d5eac79296a155d5001e04c4d2c28f203a7dd4ac5bbb0c0e358203be85a863b6c368f1159816d5a4cf0b8f6d89b
Release 3.1.0
f5-openstack-hot-supported.tar.gz aaac9adee4af968bc5110428ad19a95bceb4c0fbd9d8fa985d6db076149b55470cd0428e69b5d8e0ecb1befe06d00e062bffd9f629f07ffdea8a0abf23d2bd00
Release 3.0.0
f5-openstack-hot-supported.tar.gz 159e991e5215336697f6baf596fb417094c2603fb834385476bd26c1ae11a15d1156d35e8584519494b7f6099de4ad1b726c1d3493c8d1f7ddbc403503a907cd
Release 2.0.0
f5-openstack-hot-supported.tar.gz 1c8c4ca73aba5c3ca97ab03560254bea04d82c7e306495bc2dfaee11850c9121d88b5467fd1cb198de429bd97beaabd64897e92fa9d85e6a52eed5ba9041725b
Code :
*   **Linux**: `sha512sum `
*   **Windows using CertUtil**:  `CertUtil –hashfile  SHA512`
Version history
Last update:
‎06-Oct-2017 11:18
Updated by:
Contributors
