Problem this snippet solves:
Add, list or delete a device within BIG-IQ
Code :
#!/usr/bin/python
import argparse
import json
import logging
import sys
import restapi;
DEFAULT_BIGIQ_USER = "admin"
DEFAULT_BIGIQ_PASSWORD = "admin"
DEFAULT_BIGIQ_ACTION = "List"
#This will be used to retrieve the ID of the device we want to delete
DEFAULT_BIGIP_HOSTNAME = "your.test.lab"
LOG = logging.getLogger(__name__)
# Loads a JSON file.
def load_json_file(name):
    with file(name) as f:
        json_data = json.load(f)
    if json_data:
        json_data = json.dumps(json_data)
    return json_data
# Prints a line separator (for easy viewing).
def print_separator():
        print("-" * 80)
# Validates the HTTP/REST result.
def validate_result(result, verbose=False):
    # Any result beyond HTTP 400 is considered an error.
    if ((result == None) or (result[0] >= restapi.HTTP_400)):
        sys.exit(1)
    if verbose:
        for i in range (1, len(result)):
    LOG.info(result[i])
def retrieve_device_id(list_devices, hostname):
    for i in range (1, len(list_devices)):
    hostname_ = list_devices[i]['items'][0]['hostname']
    if (hostname == hostname_):
print(list_devices[i]['items'][0]['id'])
return(list_devices[i]['items'][0]['id'])
# Runs the BIG-IQ cloud API test suite.
def run_bigiq_tests(bigiq_address,
                    action=DEFAULT_BIGIQ_ACTION,
    hostname=DEFAULT_BIGIP_HOSTNAME,
    bigiq_user=DEFAULT_BIGIQ_USER,
                    bigiq_password=DEFAULT_BIGIQ_PASSWORD,
                    verbose=False):
    LOG.info("Running BIG-IQ Tenant tests...")
    # Initialize cloud API tester.
    LOG.info("BIG-IQ: Initializing cloud API shim...")
    cloud_api = restapi.RestApi(host=bigiq_address,
                               user=bigiq_user,
                               password=bigiq_password)
    LOG.info("BIG-IQ: Cloud API shim successfully initialized.")
    if (action == "Delete"):
    LOG.info("BIG-IQ: Delete Device...")
        list_devices = cloud_api.get_devices()
device_id = retrieve_device_id(list_devices, hostname)
        result = cloud_api.delete_device(device_id)
        validate_result(result, verbose)
        LOG.info("BIG-IQ: Device successfully deleted.")
    if (action == "List"):
    # BIG-IQ: query devices list
    LOG.info("BIG-IQ: Querying list of devices...")
    result = cloud_api.get_devices()
validate_result(result, True)
    LOG.info("BIG-IQ: Devices list successfully retrieved.")
    if (action == "Create"):
    # BIG-IQ: add device.
    LOG.info("BIG-IQ: Adding Device...")
    result = cloud_api.create_device(load_json_file("./bigiq_create_device.json"))
    LOG.info("BIG-IQ: Device successfully created.")
# Initializes logging.
def init_logging(level=logging.INFO):
    log_format = '%(asctime)-15s: %(funcName)s(): %(message)s'
    logging.basicConfig(format=log_format, level=level)
# Main entry point
def main():
    parser = argparse.ArgumentParser(description="Runs various REST-API functional tests")
    parser.add_argument('-v', '--verbose', action='store_true', default=False)
    parser.add_argument('--bigiq-address', required=True)
    parser.add_argument('--bigiq-user', default=DEFAULT_BIGIQ_USER)
    parser.add_argument('--bigiq-password', default=DEFAULT_BIGIQ_PASSWORD)
    parser.add_argument('--action', default=DEFAULT_BIGIQ_ACTION)
    parser.add_argument('--hostname', default=DEFAULT_BIGIP_HOSTNAME)
    args = parser.parse_args()
    log_level = logging.INFO
    if (args.verbose):
        log_level = logging.DEBUG
    init_logging(log_level)
    # BIG-IQ tests.
    run_bigiq_tests(bigiq_address=args.bigiq_address,
                    action=args.action,
    hostname=args.hostname,
    bigiq_user=args.bigiq_user,
                    bigiq_password=args.bigiq_password,
                    verbose=args.verbose)
    LOG.info("OK. Done testing.")
# Main entry point launcher.
if __name__ == '__main__':
    main()
Comments
Paolo_Arcagni_9
Historic F5 Account
Where can I find the restapi python package?
Paolo_Arcagni_9
Historic F5 Account
Version history
Last update:
‎09-Mar-2015 15:14
Updated by:
Contributors
