ChrisMutzel_151
Altocumulus
Altocumulus
Problem this snippet solves:
2016-07-12 Update: Newer Cloud Formation templates can be found at: https://github.com/F5Networks/f5-aws-cloudformation
WARNING You will be billed for the AWS resources used if you create a stack from this template.
Provides a easy way to launch and test BIG-IP in AWS using Amazon CloudFormation Templates.
Code :
# **2016-07-12 Update:** Newer Cloud Formation templates can be found at: https://github.com/F5Networks/f5-aws-cloudformation
  "AWSTemplateFormatVersion": "2010-09-09",
  "Description": "AWS CloudFormation Template for Hourly BIG-IP AMIs. This template launches BIG-IP as an Amazon EC2 instance.  It also creates all networking resources necessary to support BIG-IP and an application server.  No web-servers are launched as part of this CFT. **WARNING** You will be billed for the AWS resources used if you create a stack from this template.",
  "Parameters": {
    "BigIPInstanceType": {
      "Description": "F5 BIG-IP Virtual Instance Type",
      "Type": "String",
      "Default": "m3.xlarge",
      "AllowedValues": [
        "m3.xlarge",
        "m3.2xlarge",
        "c1.medium",
        "c1.xlarge",
        "cc1.4xlarge",
        "cc2.8xlarge",
        "cg1.4xlarge"
      "ConstraintDescription": "must be a valid Big-IP EC2 instance type."
    "BigIpLicensePackage": {
      "Description": "F5 BigIP Performance Type",
      "Type": "String",
      "Default": "Good",
      "AllowedValues": [
        "Good",
        "Better",
        "Best"
      "ConstraintDescription": "Must be a valid F5 Big-IP performance type"
    "BigIpThroughput": {
      "Description": "F5 BigIP Throughput",
      "Type": "String",
      "Default": "25-Mbps",
      "AllowedValues": [
        "25-Mbps",
        "200-Mbps",
        "1000-Mbps"
      "ConstraintDescription": "Please select your desired throughput"
    "KeyName": {
      "Description": "Name of an existing EC2 KeyPair to enable SSH access to the instance",
      "Type": "AWS::EC2::KeyPair::KeyName"
    "SSHLocation": {
      "Description": " The IP address range that can be used to SSH to the EC2 instances",
      "Type": "String",
      "MinLength": "9",
      "MaxLength": "18",
      "Default": "0.0.0.0/0",
      "AllowedPattern": "(\\d{1,3})\\.(\\d{1,3})\\.(\\d{1,3})\\.(\\d{1,3})/(\\d{1,2})",
      "ConstraintDescription": "must be a valid IP CIDR range of the form x.x.x.x/x."
  "Mappings": {
    "BigIPRegionMap": {
      "ap-northeast-1": {
        "Best1000": "ami-29e11229",
        "Best200": "ami-edf300ed",
        "Best25": "ami-4fe7144f",
        "Better1000": "ami-c3f300c3",
        "Better200": "ami-3fe7143f",
        "Better25": "ami-89f20189",
        "Good1000": "ami-5bc23f5b",
        "Good200": "ami-71fc0171",
        "Good25": "ami-6ffc016f"
      "ap-southeast-1": {
        "Best1000": "ami-dcebdb8e",
        "Best200": "ami-86eadad4",
        "Best25": "ami-b4eadae6",
        "Better1000": "ami-92eadac0",
        "Better200": "ami-cceada9e",
        "Better25": "ami-e8eadaba",
        "Good1000": "ami-fc5764ae",
        "Good200": "ami-12665540",
        "Good25": "ami-6c66553e"
      "ap-southeast-2": {
        "Best1000": "ami-eb5625d1",
        "Best200": "ami-03562539",
        "Best25": "ami-2556251f",
        "Better1000": "ami-0b562531",
        "Better200": "ami-09562533",
        "Better25": "ami-1f562525",
        "Good1000": "ami-e7e192dd",
        "Good200": "ami-ddf380e7",
        "Good25": "ami-855724bf"
      "eu-central-1": {
        "Best1000": "ami-9e93ae83",
        "Best200": "ami-d898a5c5",
        "Best25": "ami-de98a5c3",
        "Better1000": "ami-9493ae89",
        "Better200": "ami-9693ae8b",
        "Better25": "ami-9093ae8d",
        "Good1000": "ami-10c1fc0d",
        "Good200": "ami-e6c6fbfb",
        "Good25": "ami-f0c6fbed"
      "eu-west-1": {
        "Best1000": "ami-c7158db0",
        "Best200": "ami-d3138ba4",
        "Best25": "ami-85138bf2",
        "Better1000": "ami-c9138bbe",
        "Better200": "ami-99138bee",
        "Better25": "ami-df138ba8",
        "Good1000": "ami-695fc51e",
        "Good200": "ami-af9802d8",
        "Good25": "ami-2f128a58"
      "sa-east-1": {
        "Best1000": "ami-0d7cc710",
        "Best200": "ami-cf7dc6d2",
        "Best25": "ami-997dc684",
        "Better1000": "ami-4d73c850",
        "Better200": "ami-dd7dc6c0",
        "Better25": "ami-cd7dc6d0",
        "Good1000": "ami-4b09b256",
        "Good200": "ami-d91aa1c4",
        "Good25": "ami-297dc634"
      "us-east-1": {
        "Best1000": "ami-7c9ab114",
        "Best200": "ami-fe81aa96",
        "Best25": "ami-cc81aaa4",
        "Better1000": "ami-c281aaaa",
        "Better200": "ami-ce81aaa6",
        "Better25": "ami-f281aa9a",
        "Good1000": "ami-488ca720",
        "Good200": "ami-588da630",
        "Good25": "ami-e08ea588"
      "us-west-1": {
        "Best1000": "ami-614cad25",
        "Best200": "ami-674dac23",
        "Best25": "ami-734dac37",
        "Better1000": "ami-254dac61",
        "Better200": "ami-474dac03",
        "Better25": "ami-0f4dac4b",
        "Good1000": "ami-f737d7b3",
        "Good200": "ami-014aab45",
        "Good25": "ami-674aab23"
      "us-west-2": {
        "Best1000": "ami-d1735de1",
        "Best200": "ami-7b755b4b",
        "Best25": "ami-1d755b2d",
        "Better1000": "ami-2f755b1f",
        "Better200": "ami-75755b45",
        "Better25": "ami-0f755b3f",
        "Good1000": "ami-a1775991",
        "Good200": "ami-17775927",
        "Good25": "ami-e57658d5"
    "AWSBigIPThrougput": {
      "25-Mbps": {
        "Good": "Good25",
        "Better": "Better25",
        "Best": "Best25"
      "200-Mbps": {
        "Good": "Good200",
        "Better": "Better200",
        "Best": "Best200"
      "1000-Mbps": {
        "Good": "Good1000",
        "Better": "Better1000",
        "Best": "Best1000"
  "Resources": {
    "VPC": {
      "Type": "AWS::EC2::VPC",
      "Properties": {
        "EnableDnsSupport": "true",
        "EnableDnsHostnames": "true",
        "CidrBlock": "10.0.0.0/16",
        "Tags": [
            "Key": "Application",
            "Value": {
              "Ref": "AWS::StackName"
    "ManagementSubnet": {
      "Type": "AWS::EC2::Subnet",
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "CidrBlock": "10.0.0.0/24",
        "Tags": [
            "Value": {
    "ExternalSubnet": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "CidrBlock": "10.0.1.0/24",
        "AvailabilityZone": {
          "Fn::GetAtt": [
            "ManagementSubnet",
            "AvailabilityZone"
        "Tags": [
            "Value": {
    "InternalSubnet": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "CidrBlock": "10.0.2.0/24",
          "Fn::GetAtt": [
            "ManagementSubnet",
            "AvailabilityZone"
        "Tags": [
            "Value": {
    "InternetGateway": {
      "Type": "AWS::EC2::InternetGateway",
      "Properties": {
        "Tags": [
            "Value": {
    "AttachGateway": {
      "Type": "AWS::EC2::VPCGatewayAttachment",
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "InternetGatewayId": {
          "Ref": "InternetGateway"
    "ExternalRouteTable": {
      "Type": "AWS::EC2::RouteTable",
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "Tags": [
            "Value": {
            "Key": "Network",
            "Value": "External"
    "ExternalRoute": {
      "Type": "AWS::EC2::Route",
      "Properties": {
        "RouteTableId": {
          "Ref": "ExternalRouteTable"
        "DestinationCidrBlock": "0.0.0.0/0",
        "GatewayId": {
    "ExternalSubnetRouteTableAssociation": {
      "Type": "AWS::EC2::SubnetRouteTableAssociation",
      "Properties": {
        "SubnetId": {
          "Ref": "ExternalSubnet"
        "RouteTableId": {
    "InternalRouteTable": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "Tags": [
            "Value": {
            "Key": "Network",
            "Value": "Internal"
    "InternalRoute": {
      "Properties": {
        "RouteTableId": {
          "Ref": "InternalRouteTable"
        "GatewayId": {
    "InternalSubnetRouteTableAssociation": {
      "Properties": {
        "SubnetId": {
          "Ref": "InternalSubnet"
        "RouteTableId": {
    "ManagementRouteTable": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "Tags": [
            "Value": {
            "Key": "Network",
            "Value": "Mgmt"
    "ManagementRoute": {
      "Properties": {
        "RouteTableId": {
          "Ref": "ManagementRouteTable"
        "GatewayId": {
    "ManagementSubnetRouteTableAssociation": {
      "Properties": {
        "SubnetId": {
          "Ref": "ManagementSubnet"
        "RouteTableId": {
    "SubnetRouteTableAssociationManagement": {
      "Properties": {
        "SubnetId": {
        "RouteTableId": {
    "SubnetRouteTableAssociationInternal": {
      "Properties": {
        "SubnetId": {
        "RouteTableId": {
    "SubnetRouteTableAssociationExternal": {
      "Properties": {
        "SubnetId": {
        "RouteTableId": {
    "BigIPManagementSecurityGroup": {
      "Type": "AWS::EC2::SecurityGroup",
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "GroupDescription": "Enable SSH access via port 22",
        "SecurityGroupIngress": [
            "IpProtocol": "tcp",
            "FromPort": "22",
            "ToPort": "22",
            "CidrIp": {
              "Ref": "SSHLocation"
            "FromPort": "443",
            "ToPort": "443",
            "CidrIp": {
    "BigIPExternalSecurityGroup": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
            "FromPort": "80",
            "ToPort": "80",
            "CidrIp": "0.0.0.0/0"
            "FromPort": "443",
            "ToPort": "443",
    "BigIPInternalSecurityGroup": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
            "FromPort": "8080",
            "ToPort": "8080",
            "CidrIp": "10.0.2.0/24"
            "FromPort": "22",
            "ToPort": "22",
            "IpProtocol": "icmp",
            "FromPort": "-1",
            "ToPort": "-1",
    "ManagementInterface": {
      "Type": "AWS::EC2::NetworkInterface",
      "Properties": {
        "Description": "Management Interface for the BigIP",
        "GroupSet": [
            "Ref": "BigIPManagementSecurityGroup"
        "SubnetId": {
    "InternalInterface": {
      "Properties": {
        "Description": "Internal Interface for the BigIP",
        "GroupSet": [
            "Ref": "BigIPInternalSecurityGroup"
        "SubnetId": {
    "ExternalInterface": {
      "Properties": {
        "Description": "External Interface for the BigIP",
        "GroupSet": [
            "Ref": "BigIPExternalSecurityGroup"
        "SubnetId": {
        "SecondaryPrivateIpAddressCount": "1"
    "ManagementIPAddress": {
      "Type": "AWS::EC2::EIP",
      "DependsOn": "AttachGateway",
      "Properties": {
        "Domain": "vpc"
    "InternalWebserverIPAddress": {
      "Properties": {
        "Domain": "vpc"
    "ManagementIPAssociation": {
      "Type": "AWS::EC2::EIPAssociation",
      "Properties": {
        "AllocationId": {
          "Fn::GetAtt": [
            "ManagementIPAddress",
            "AllocationId"
        "NetworkInterfaceId": {
          "Ref": "ManagementInterface"
    "VIPIPAddress": {
      "Properties": {
        "Domain": "vpc"
    "VIPIPAssociation": {
      "Properties": {
        "AllocationId": {
          "Fn::GetAtt": [
            "VIPIPAddress",
            "AllocationId"
          "Ref": "ExternalInterface"
        "PrivateIpAddress": {
          "Fn::Select": [
            "0",
              "Fn::GetAtt": [
                "ExternalInterface",
                "SecondaryPrivateIpAddresses"
    "BigIpInstance": {
      "Type": "AWS::EC2::Instance",
      "Properties": {
        "ImageId": {
          "Fn::FindInMap": [
            "BigIPRegionMap",
              "Ref": "AWS::Region"
              "Fn::FindInMap": [
                "AWSBigIPThrougput",
                  "Ref": "BigIpThroughput"
                  "Ref": "BigIpLicensePackage"
        "InstanceType": {
          "Ref": "BigIPInstanceType"
        "KeyName": {
          "Ref": "KeyName"
        "Tags": [
            "Value": {
          "Fn::GetAtt": [
            "ManagementSubnet",
            "AvailabilityZone"
        "NetworkInterfaces": [
            "Description": "Management Interface",
            "DeviceIndex": "0",
            "Description": "External Interface",
            "DeviceIndex": "1",
            "Description": "Internal Interface",
            "DeviceIndex": "2",
              "Ref": "InternalInterface"
    "WebServerSecurityGroup": {
      "Properties": {
        "VpcId": {
          "Ref": "VPC"
        "GroupDescription": "Enable HTTP access via port 80",
            "FromPort": "80",
            "ToPort": "80",
            "FromPort": "80",
            "ToPort": "80",
            "FromPort": "22",
            "ToPort": "22",
            "FromPort": "-1",
            "ToPort": "-1",
  "Outputs": {
    "BigIpManagementIp": {
      "Value": {
        "Fn::Join": [
            "https://",
              "Fn::GetAtt": [
                "BigIpInstance",
                "PublicIp"
      "Description": "BigIP Management GUI"
    "PublicVIP": {
      "Value": {
        "Fn::Join": [
            "http://",
              "Ref": "VIPIPAddress"
            ":80"
    "InternalInterfacePrivateIp": {
      "Description": "Internally routable IP of internal interface on BIG-IP",
      "Value": {
        "Fn::Join": [
            "Fn::GetAtt": [
              "InternalInterface",
              "PrimaryPrivateIpAddress"
    "ExternalInterfacePrivateIp": {
      "Description": "Internally routable IP of external interface on BIG-IP",
      "Value": {
        "Fn::Join": [
            "Fn::GetAtt": [
Tested this on version:
11.6
Version history
Last update:
‎18-Jun-2015 13:24
Updated by:
Contributors
