Chris_Miller
Altostratus
Altostratus
Problem this snippet solves:
For customers leveraging Akamai, all traffic is routed through Akamai regional servers. This means using source address persistence will severely limit load distribution. While cookie persistence is an ideal option, persisting via Akamai's True-Client-IP header can be a good fallback. Akamai inserts this header in each request with a value of the original user's IP address.
How to use this snippet:
This rule only requires an LTM license and should run on v9-11. Make sure to use a OneConnect profile on the virtual server to ensure
Code :
  set True_Client_IP [HTTP::header "True-Client-IP"]
  if { $True_Client_IP ne "" } {
    persist uie $True_Client_IP
    log local0. "[IP::client_addr]:[TCP::client_port]: True-Client-IP: [HTTP::header value True-Client-IP], persist record: [persist lookup uie $True_Client_IP]"
Tested this on version:
9.0
Comments
JRahm
Community Manager
Community Manager
Contributed by Chris Miller
jaiAdityaSingla
if we enable X-forward-insert in the HTTP profile, would also do the same job instead of using the iRule here, Request Headers Received at the Server would have the actual client IP. Jason/Chris please correct me if I'm wrong?
Manjunath_Murug
Hi .. Nice code .. Can u share me some description about this ?? I am new to persist feature . If possible , please share some O/P examples
Matthew_Siers_1
Historic F5 Account
Cool thanks. This is good for Silverline gen knowledge since a few of our customers usually end up coming via ADN/CDN, etc.
Rory_Hewitt_F5_
Altocumulus
Altocumulus
Note that whilst the default value of the 'True Client IP' passed through from Akamai is indeed True-Client-IP, your Akamai configuration may use a different value... Check in your Akamai config first.
Version history
Last update:
‎30-Jan-2015 06:50
Updated by:
Contributors
