YourAmigo lookup and forward irule
Having issues with new F5’s lookup forwarding YourAmigo.com. Have a ticket opened with F5 and the engineer provided the following solution from DevCentral https://devcentral.f5.com/community/group/asg/50/aft/27982/showtab/groupforums. Still getting TCL error.
Rewrite HTTP Host header
HTTP::header replace Host “blah.youramigo.com
Hold HTTP and perform DNS lookup
NAME::lookup blah.youramigo.com
HTTP::collect
when NAME_RESOLVED {
log local0. “Forwarding to YourAmigo at [NAME::response address 0]”
node [NAME::response address 0] 80
HTTP::release
node 69.36.35.147 80
Mon Mar 18 14:11:57 GMT 2013 err tmm tmm[7845] 01220001 TCL error: /Common/YourAmigo-Baby_offsite_logger - while executing “NAME::response address 0”
Mon Mar 18 14:11:57 GMT 2013 info tmm tmm[7845] Rule /Common/YourAmigo-Baby_offsite_logger : Forwarding to YourAmigo at
cat /var/named/config/named.conf
restrict rndc access to local machines
use the key in the default place: /config/rndc.key
controls { inet 127.0.0.1 port 953 allow { 127.0.0.1 ;}; };
logging {
channel logfile {
syslog daemon;
severity error;
print-category yes;
print-severity yes;
print-time yes;
category default {
logfile;
category config {
logfile;
category notify {
logfile;
options {
listen-on port 53 { 127.0.0.1; };
listen-on-v6 port 53 { ::1; };
set this to yes when you want to resolve off
box. setting it to yes when you dont actuallly
have a bind server configured will result in
bind timeouts for many commmands
recursion yes;
forward only;
directory “/config/namedb”;
allow-transfer {
localhost;
check-names master warn;
change to “no” if you want to be able to add
MX records that do not reference a record that has an A record
check-integrity yes;
max-journal-size 1M;
forwarders {209.x.x.x; 209.x.x.x; };
acl “zrd-acl-000-000” {
127.10.0.0;
acl “local-loopback-clients” {
127.0.0.0/8;
view “internal” {
match-clients { “local-loopback-clients”; };
recursion yes;
view “external” {
match-clients { “zrd-acl-000-000”; any; };
server 209.x.x.x {
server 209.x.x.x {
Can you please enable the logging and confirm that you are getting a value other than null returned with the [NAME::response address 0] command.
I enabled logging.
Error:
Mon Mar 18 20:01:10 GMT 2013 err tmm1 tmm1[7846] 01220001 TCL error: /Common/YourAmigo-Baby_offsite_logger - while executing “NAME::response address 0”
Mon Mar 18 20:01:10 GMT 2013 info tmm1 tmm1[7846] Rule /Common/YourAmigo-Baby_offsite_logger : Forwarding to YourAmigo at
HTTP::collect
HTTP::release
Sorry, I wasn’t clear, please remove the hash from this line;
log local0. "Forwarding to YourAmigo at [NAME::response address 0]"
I removed the from the log. Looks like there is a routing issue, there is 2 DFGW’s defined on the F5’s. Gui shows DFGW as 0.0.0.0 0.0.0.0 63.X.X.X. Netstat -rn is showing the following. Looks like the network deployment team is entering the routes via cmd line. Need to check with F5 to resolve.
netstat -rn
Active F5:
0.0.0.0 10.X.X.X 0.0.0.0 UG 0 0 0 eth0
Standby F5
0.0.0.0 63.X.X.X 0.0.0.0 UG 0 0 0 SLB_External
This is a common misconception (I think that’s the right word!) There are effectively two routing tables on a BIG-IP, one for the Linux Host Management System (HMS) and one for TMM/LTM. The HMS route(s) can only be viewed at the CLI and generally use eth0; these routes are only used for management traffic such as SNMP sourced from the device, not for traffic handled by LTM. The LTM routes as seen in the GUI or at the CLI with [tmsh] show net route command are the routes used when handling traffic via a VS, NAT or SNAT.
Anyway, this may all be moot, according to this article: https://devcentral.f5.com/wiki/iRules.NAME\_\_lookup.ashx - “If you do not include the @{IP/Virtual Name} argument, local bind will be the target of the query. If your local bind is not set up to query recursively, and is not authoritative for the domain in question, you will receive no response”
Is that what you are seeing, no response?
as Steve mentioned, can you try to include @IP in NAME::lookup instead of using local bind?
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   destination 172.28.19.252:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
   log local0. "--"
   HTTP::collect
   HTTP::header replace Host "www.youramigo.com"
   NAME::lookup @8.8.8.8 www.youramigo.com
   log local0. "--"
   HTTP::release
when HTTP_RESPONSE {
   log local0. "--"
   log local0. "server [IP::server_addr]:[TCP::server_port] | status [HTTP::status]"
 client
[root@centos251 ~] curl -I http://172.28.19.252/
HTTP/1.1 200 OK
Date: Wed, 20 Mar 2013 04:31:21 GMT
Server: Apache
Last-Modified: Thu, 21 Feb 2013 05:45:08 GMT
ETag: "c419ae-429a-4d63593cae100"
Accept-Ranges: bytes
Content-Length: 17050
Vary: Accept-Encoding
P3P: CP="NOI NID ADMa OUR IND UNI COM NAV"
Content-Type: text/html
 /var/log/ltm
[root@ve10:Active] config  tail -f /var/log/ltm
Mar 20 12:20:30 local/tmm info tmm[4950]: Rule myrule : --
Mar 20 12:20:30 local/tmm info tmm[4950]: Rule myrule : serevr 69.36.35.145:80 | status 200
if you want to use local bind, i understand you need to configure “BIND Forwarder Server List” (system > devices > dns) and correct recursion option which is described in the sol below.
sol12224: Configuring the BIND forwarder server list does not correctly set additional options for the named.conf file
404 Page not found | BIG-IP Documentation
hope this helps.
Just to clarify would the 8.8.8.8 be my dns resource server?
All,
Works like a champ! Thanks for all of input!
Bryce
