I have a WWW redirect in place that works, however when a user goes to www.domain.com/something they are redirected to just domain.com vs going to domain.com/something.
How can I modify or create a new rule to make it work so they maintain the URI string/path after the redirect happens.
I’m running 10.2.3 and my current rule is below:
switch "[string tolower [HTTP::host]]" {
"www.domain.com" {
HTTP::respond 301 Location "http://domain.com"
[\code]
Thanks,
Bob
nathe
2
Bob,
Does this work by appending HTTP::uri?
switch “[string tolower [HTTP::host]]” {
“www.domain.com” {
HTTP::respond 301 Location “http://domain.com”[HTTP::uri]
N
I get an error when I check the syntax:
line 4: [parse error: extra characters after close-quote] [[HTTP::uri]]
Thanks,
Bob
Thanks Nathan..I see what the problem was now..Just moved my quote over and yes that did the trick..
Thanks again!
Bob
nathe
5
Bob
Sorry about that, should’ve checked my word - too quick to click Submit…more haste, less speed in future.
Glad it works
N
