Wildcard Virtuals & Partitions
I’m setting up a new LTM/AFM pair and want to use partitions to separate the AFM virtuals from the LTM virtuals. I am having a hard time understanding how to process outbound traffic to the internet (unknown destinations).
Normally I would just set up a wildcard forwarding VS and enable it on the specific VLANs I want to have outside access. Since the VLANs are in partitions, I have to create one for each. However I receive an error when attempting to create two 0.0.0.0/0 VSs even when they are enabled on different VLANs.
01070726:3: virtual server /SharedLB/FwdVS-Wildcard in partition SharedLB cannot reference virtual address /SharedFW/0.0.0.0 in partition SharedFW
Is this expected behavior? If so, what are my options?
The problem is I have separate VLANs for the normal VS addresses and I do not want to enable access for them. Would creating a wildcard VS and disabling only those VLANs work instead, regardless of which partition it resides?
Would I be better off creating a FastL4 VS and using a default gateway pool (the same one that my default route uses)?
I’m sure I could get this working with multiple route domains but I’d like to avoid that complexity if at all possible.
Thinking more about this, would a solution be to enable it on all VLANs but use AFM to deny traffic on self-IPs for the VLANs I do not want to have outside internet access?
you may want to look into route domains…
this isnt a RTFM but more of a pointer as my route domain understanding is very basic and may not include wildcard VS’s but if it does then happy days!
Yea I’m certain route domains would work but I want to avoid them as to not to confuse the lower level support guys. I’ve also heard many horror stories of route domain issues with upgrades…
Hi garypayton,
I am having exactly the same issue creating wildcards for different partitions. Although we use route domains in other F5s without AFM, for the new ones I would like to avoid using Route domains for the same reasons you stated in the post.
How did you configure your system eventually?
Thanks, Wahezu.
Sorry I literally left that company a couple weeks after making that post, I am not sure how they ended up configuring it…
Just in case someone is interested in the solution I took. Here it is the link for this:
Rgds
A shared object (i.e. a wildcard virtual address 0.0.0.0/0) needs to be placed in the common partition to be referenced in different administrative partitions.
configuration partitions are just that, IP / routing wise you are in the same scope so you can’t use the same IP / Subnet on two places.
