When someone set up our F5 they created multiple partitions for different segments.
We are trying to reconfigure the F5 to all everything running from the common partition.
We currently have our public wifi authentication happening via the F5 on a subnet REDACTED
That is working fine because we have a route with REDACTED to the correct gateway.
I also want to create VS with the subnet REDACTED
Now we have the self ip’s in place, and the Vlans are in the same route domain (0).
The issue I am facing is I can get to the back end of the VS, however if I remove the default route for the public wifi and add the gateway for the REDACTED network I can then access that but not the public Wi-Fi.
Can anyone help or provide a suggestion as to how I can get both subnets working on the same partition?
I tried doing this do you mean by adding %1 for example on the gateway? I tried this and the VS still wouldn’t work however if I create a different partition with a default gateway it works in that partition.
So you are correct it does it when I add a partition but what I really want is two different subnets working from the common partition.
When I try to have two subnets working from the common partition the only subnet that works is the one with the default gateway configured, how can I get them both working?
