Hello folks, I have a POC I’m testing out. The idea is a web user does a HTTP POST with token that matches a value in a data group. If it matches it will connect them to the pool. I am running into trouble with HTTP_REQUEST_DATA not firing. I’ve done some debugging by placing log statements within my many IF clauses.
Running LTM 11.5.1 HF4
when CLIENT_ACCEPTED {
set usertoken "1"
end of CLIENT_ACCEPTED
when HTTP_REQUEST_DATA {
log local0. "HITTING http-request-data clause"
foreach x [split [string tolower [HTTP::payload]] "&"] {
if { $x starts_with "token=" } {
set usertoken [lindex [split $x "="] 1]
log local0. "User $usertoken attempted login from [IP::client_addr]:[TCP::client_port]"
end of HTTP_REQUEST_DATA
set MasterToken [class match -value "num" equals data_POC ]
if { ([IP::addr [IP::client_addr] equals "10.255.255.4/32"]) }{
Admin Page displayed based on source IP
HTTP::respond 200 content "Token is $MasterToken"
log local0. "HITTING 10.30.0.0 clause"
Check if request is a POST
if { ([string tolower [HTTP::method]] eq "post" ) } {
log local0. "HItting post clause"
check content length is less than a 1Mb, or capture 1Mb only
if { ([HTTP::header "Content-Length"] ne "") && ([HTTP::header "Content-Length"] <= 1048576)}{
log local0. "hitting content-length clause"
set content_length [HTTP::header "Content-Length"]
set content_length 1048576
Check if $content_length is not set to 0
if { $content_length > 0} {
log local0. "HITTING http-collect clause"
HTTP::collect
this fires the HTTP_REQUEST_DATA event
Check if $gloabal_usertoken and $MAsterToken match
if { ($usertoken eq $MasterToken) }{
MATCH page
HTTP::respond 200 content " MATCH $usertoken and $MasterToken "
else {
NO match page
HTTP::respond 200 content " NO MATCH $usertoken and $MasterToken "
NO POST data
HTTP::respond 200 content [ifile get "iFile_TokenPage"]
end of HTTP_REQUEST
- usertoken = dynamic variable that gets set in HTTP_REQUEST_DATA based on the POST field=token and it’s value, and read in HTTP_REQUEST where it is compared to the Data Group value.
Interesting enough the client logic is making it to HTTP::collect
Jun 10 17:09:01 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : HItting post clause
Jun 10 17:09:01 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : hitting content-length clause
Jun 10 17:09:01 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : HITTING http-collect clause
Jun 10 17:09:02 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : HItting post clause
Jun 10 17:09:02 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : hitting content-length clause
Jun 10 17:09:02 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : HITTING http-collect clause
Jun 10 17:09:03 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : HItting post clause
Jun 10 17:09:03 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : hitting content-length clause
Jun 10 17:09:03 deltm02 info tmm3[10524]: Rule /Common/irule_tokenPage : HITTING http-collect clause
Lastly here is the iFile_TokenPage just incase
Any help would be greatly appreciated.
