What is the best practice for migrating from iseries to rseries?
hi ,we plan to migrate to new r-series F5 (v15.1.x) from i-series  legacy appliance v13.x.x. We will create the same vlans and IP address config, but the physical interfaces will be different. The new r-series appliance is already licensed. What is the best practice for this migration?
option1:
import the whole UCS file to new r-series appliance. after importing the ucs to new appliance, what are the next steps to complete the whole migration?
option2:
copy the config for every module, for example to copy ltm config first, then gtm, final AFW …
can someone please advise, thanks in advance!
Hi Herman2024,
For me, the best migration strategy is:
  1. Upgrade the i-series to v15.1.x, in this case, you could set offline one of the current devices and create a cluster with the new r-series device, make a failover, and test the services “it only applies if APM is not provisioned”
  2. If APM is provisioned you have two options:
    1. Big bang - migrate the configs into new devices " I recommend updating the i-seres to avoid possible issues in the config migration", so in this case, you have to disable the current devices and then enable the new devices “at the SW level is the best option because you can configure the HA between the devices only provisioning the vlan for this propose but you have to replace the current IPs in the config”
    2. Migrate by services with a different networking config - In this case, the idea is migrating by group of services or VIPs, you have to keep a different network configuration, and in the new devices you have to disable the ARP, for VIPs and SNAT and the migration is easy, you have to disable ARP in the current devices for a group of services and enable in the new devices.
Note: If your current i-series can´t be upgraded because the support contract is over, you could contact your F5 SE to request a temporary license to upgrade the devices.
I hope it works.
In this link, you have the info to restore the UCS:
Thanks @Sebastiansierra for your kind advice! we don’t want to upgrade software to 15.1.x on the i-series first because of the impact to the production. Can we directly upload the v13.1.x UCS file (i-series) onto r-series (OS version is 15.1.x)?  APM module is  not provisioned.  Thanks in advance!
Hi Herman2024,
If you don´t want to affect production in this migration, I recommend you upgrade the current devices from version 13 to 15 and then upload the new UCS in the r-series devices. There are many changes from 13 to 15, and the configuration is transformed in the upgrade process, so no, I don’t recommend you try to load the UCS from 13 to 15; it will probably fails.
You could try to use the platform to migrate in the load, but again, the most probably is that the load fails.
Hi @Sebastiansierra ,
thank you so much for your advice. Our current f5 i-series is very old unit and we don’t prefer to upgrade it to 15.1.x from 13.1.x . Can we downgrade r-series OS from 15.1 to 13.1 ,then upload the UCS of i-series onto it, finally upgrade OS on r-series to 15.1? Please advise, thanks !
Hi Herman2024,
Unfortunately, the r-series only supports version 15.x and 17.x, so you can deploy version 15 to have the base and install a new volume in version 13 to upload the ucs and migrate the config. This process is not supported and probably not official; it can work, so why not, I recommend you test it.
But again, the most recommended is upgrade your current i-series devices, because its support version 15 and 17 too.
Version 15.1.x is the absolute minimum supported on rSeries, so you will have to upgrade first.  You’ll want to use “Journeys” to generate a compatible UCS file for the migration.  It’ll run through all the issues you need to resolve as well.
Hi Herman2024,
Another way to migrate your configuration from 13 to 15 is to request a VE license to your F5 SE or sales representative to deploy a virtual machine in version 13.1 and upgrade it to 15.X generates a UCS and imports it in the r-series.
In this case remember that VLANs, LACP are configured directly in the chassis, so you have to skip this config in your VE “the vlans can stay”
@Herman2024 What procedure did you follow and any issues you saw? I was looking at some documentation and had few questions with the procedure I was thinking to follow
  1. From the iSeries platform (iF5-A(Active) and iF5-B(Standby)), need to take backups and move them to the /shared folder and edit the UCS file(bigip_base.conf for LTM and bigip_gtm.conf for GTM) by modifying the Management Ips, Adding new Vlans(as I want to have new subnet for VIPs), creating new self IPs for all the node subnets and edit the existing domain to a new domain(ex:ab.xyz.com to dc.xyz.com). Modified files are iF5-A.ucs and iF5-B.ucs.        - We need to remove trunk config from the new UCS file(K50152613), so do we remove the full config including the config where trunk has all the vlans added along with deleting the trunk interface? We have to manually add the vlans and Trunks through F5OS?        -How can we edit iApps as they are no longer supported?
  2. On the new R-Series F5s, Bring them up and configure them for HA. Now when I copy using “platform migrate”  On the R-Series rF5-A(Active) and rF5-B(Standby), tmsh load sys ucs /tmp/iF5-A.ucs platform-migrate for rF5-A      tmsh load sys ucs /tmp/iF5-B.ucs platform-migrate for rF5-B.                                                I see that in the KB article, it saves the non compatible config in /var/local/ucs/platform_migrate_ignored_objects
Based on this K82540512, Looks like interfaces, trunks and Vlans are not copied? Does it copy the VIPs, nodes, pool members without Vlans? and should we be doing this after manually creating the Trunks and Vlans on F5OS?
