webtop applications
Forumn members
Is it possible to present non web based applications to a webtop? I’m thinking things like Windows admin tools, putty, microsoft resource kit tools and even perhaps fat clients for lob applications?
Roo
It is not. The webtop, and APM in general, is intended for TCP/IP-based (and specifically HTTP-based) applications. You can, however, create a network or application access tunnel (ie. SSLVPN) and then have it attempt to launch the local application, potentially with command line options.
Thanks Kevin. Will investigate this. I think the best option would be then to simply present a full desktop via rdp and have the necessary tools installed to that.
Appreciate the quick response!
