Hi all,
How can I create a new Volume in v11 or v11.1? In the section System > Disk Management, I can delete Volume or db already created but I don’t see how to Create a new volume.
Any Idea?
Thanks.
Hi all,
Any Idea?
Thanks.
volume is not needed to be created before installing. it can be done in one shot.
root@ve1100(Active)(/Common)(tmos) show sys software
Sys::Software Status
Volume Product Version Build Active Status
HD1.1 BIG-IP 11.0.0 8037.0 no complete
HD1.2 BIG-IP 11.0.0 8131.0 yes complete
HD1.3 none none none no complete
root@ve1100(Active)(/Common)(tmos) install sys software hotfix Hotfix-BIGIP-11.0.0-8131.0-HF1.iso volume HD1.4 create-volume
HD1.4 BIG-IP 11.0.0 8037.0 no installing 0.000 pct
Yes, via cli you can create the volume at the installation but via the GUI, you have to select an existing Volume, how can I create a new Volume before launch the installation?
but via the GUI, you have to select an existing Volumecan’t you type volume set name? i am running 11.0.0 hf1 and am able to type e.g. 5 when installing.
Posted By Alscion on 12/02/2011 12:47 AM
In Version 11.1.0 you can type a name of a new volume or choose from the drop down box.
So, if you want to create a volume name HD1.4, type the number 4 in the selection field.
Hope that helps.
I replaced a blade on a VIPRION 2400 VCMP 16 (RMA) and two vCMP came with orginal volumes while two did not. They only had one volume so I could not do the upgrade.
Here is what I found to work.
from the command line (tm shell)
(/Common)(tmos) install sys software image BIGIP-11.3.0.2806.0.iso volume HD1.2 create-volume
You can also boot.
then I installed the hotfix ei:
install sys software hotfix Hotfix-BIGIP-11.3.0-3022.0-HF3.iso volume HD1.2
Thank you. That fixed by issue perfectly!
First you have to import the Hoftix via GUI
