Using variables as the match expression on the switch command
I’m fairly certain the answer to this is no (though Tcl reference suggests it is allowed), but can the expression to match against on a switch command be defined as a variable.
switch [HTTP::uri]  {
            "$matchpage1"  {
            "$matchpage2"  {
You can do it, but it’s kind of awkward. The issue is the surrounding “{” and “}” around the comparison strings that’s causing the strings to be treated as literals. If you remove the enclosing curly braces and end each line with a continuation character, it will work. Something like this
switch -- [HTTP::uri] \
  "$matchpage1" {
  "$matchpage2" {
Check out the wiki switch topic for an example (at the bottom)
Hope this helps…
-Joe
Thank you, brilliant. And thank you for the explanation re the surrounding brackets. Doug.
No problem. If you think this answered your question, can you mark the question as a correct answer? Thanks!
-Joe
