I have a load balancer that sits in front of two servers. Currently http requests come into the load balancer on port 8888 and then are sent to Server A on port 8888 or Server B on port 8888.
I need to change this so the load balancer will send requests to Server A and B on port 7777 if the client ip is equal to a specified list of ip’s.
Hope that makes sense.
Thanks in advance for any help.
You just need to create a different pool on port 7777 and then select that pool when the client list matches. You can set up your IP list as a Data Group and then use matchclass to compare the client IP to the list. So something like this: (not syntax tested)
if {[matchclass [IP::client_addr] equals $::your_ip_list] }{
pool 7777_pool
Hope that helps,
Denny
DP,
Thanks, I will give it a try.
