URI Rewrite Help
We want to take all requests from a particular IP to a particular URI, and add an additional directory to the URI. We do not want to redirect.
For example, if a request from 2.2.2.2 comes in to /SOAPAPI, I want to rewrite the URI to /SOAPAPI/Test
So far, the iRule I created hasn’t worked.
if { ([IP::client_addr] equals “2.2.2.2”) and ([HTTP::uri] starts_with “/SOAPAPI”) } {
HTTP::uri “/SOAPAPI/Test[string range $uri 8 end]”
I lifted this example from DevCentral and I didn’t get an error when I created the rule.
The F5 sends a reset when I test it and it doesn’t pass the traffic to the inside.
If anybody has some working rules that do the same thing or sees something I am doing wrong, please let me know.
I believe that the reason why you’re getting a reset is that you’re referencing a variable that was never set: the $uri variable. Try setting that variable first
set uri [HTTP::uri]
to get rid of the resets, then add some logging to see what is going on. You’re on the right track…
-Matt
Thanks Matt,
I have it working now with [HTTP::uri], plus some other ideas I lifted from other posts…
start debug
set testuri [HTTP::uri]
log local0.debug “> ****StartURI=‘$testuri’”;
end debug
set variables
set origUri
set origString “/SOAPAPI”;
set newString “/SOAPAPI/test”;
regsub -all $origString $origUri $newString newUri
start debug
log local0.debug “> ****EndNewURI=‘$newUri’”;
end debug
write the new URI to HTTP session
HTTP::uri $newUri
string replace
Much Appreciated,
Paul
Good work! Just as a suggestion, you may consider using string map instead of regsub, as it’s way more efficient and CPU friendly. Here’s a recent example of its use for a very similar task: http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&postid=60029&view=topic
-Matt
That is the very example I lifted it from. I’m not familiar enough with the scripts to take the original scripts (with regsub) and make the changes suggested in the followup posts.
I’ll work at rewriting it.
Paul
Also, the suggestion in that post uses a redirect instead of a rewrite. I’ll search some more on string map.
I think something like this may work for you (untested, syntax or otherwise):
set newURI [string map {"/SOAPAPI" "/SOAPAPI/test"} [HTTP::uri]]
Good luck!
-Matt
Matt,
You are a master. I used that and removed the debugging commands for a short and sweet script.
if { ([IP::addr [IP::client_addr]/28 equals 216.57.132.112]) and ([HTTP::uri] starts_with “/SOAPAPI”) } {
set variables
set newUri [string map {“/SOAPAPI” “/SOAPAPI/barclays”} [HTTP::uri]]
HTTP::uri $newUri
string replace
Thanks A Million,
Paul
