In order to run a platform migration with a UCS restore from a FIPS licensed platform (physical to virtual), you need to make some modifications to the UCS file. This requires decryption of the file using article https://my.f5.com/manage/s/article/K58543794 to facilitate extraction and modification of the .conf files.
My questions are twofold:
(1) On a FIPS licensed platform, do you have to re-encrypt the file in order to load it? I know you can’t run a backup unless a passphrase is specified.
(2) What is the string to re-encrypt the file? I’ve tried the following command to no avail:
gpg --symmetric --cipher-algo AES128 --output /var/local/ucs/backup-encrypted.ucs /var/local/ucs/backup-decrypted.ucs
I’m clearly missing something here. I constructed the command from the guidance found within myF5 and when performing the restore, I’m getting an “Unexpected Error: UCS loading process failed.” error.
If anyone can assist, I’d greatly appreciate it. If an encrypted UCS is NOT required to restore a FIPS licensed platform, then that’s all good as well!
Not sure if your issue was solved and if anyone has reached out to you. I’m here to provide some answers and hopefully, it answers yours.
If you’re planning a platform migration or recovery involving a FIPS-licensed BIG-IP (for example, moving from physical to virtual), you’ll likely need to extract, modify, and restore a UCS (User Configuration Set) file. There’s a lot of confusion around encryption requirements and the right way to handle UCS files on FIPS platforms, so here’s a comprehensive guide based on F5’s official documentation and best practices.
Do You Need to Re-Encrypt the UCS File for FIPS Restore?
Short answer:
No, you do not need to manually re-encrypt a UCS file to restore it on a FIPS-licensed platform. The restore process depends on how the UCS was originally created:
If the UCS was created with a passphrase (encrypted), you must provide that passphrase during the restore.
If the UCS was created without a passphrase (unencrypted), you can restore it without a passphrase.
Important:
On FIPS platforms, you cannot create a new UCS without specifying a passphrase, but you can restore an unencrypted UCS if you have one from another system.
Do not use manual GPG commands to encrypt or re-encrypt a UCS file for F5 restore. The correct and supported way is to use the BIG-IP command line:
tmsh save sys ucs <filename> passphrase <your_passphrase>
This command ensures the UCS is encrypted in the format expected by BIG-IP.
If you’ve extracted and modified a UCS (for example, to edit configuration files), repackage it as a tar.gz, then use the above command to re-encrypt it on a BIG-IP system.
Why not use GPG directly?
Manual GPG encryption (even with the correct cipher) does not produce a UCS file that BIG-IP can restore. Attempting to restore such a file will result in errors like “Unexpected Error: UCS loading process failed.” (K5437, K13537502)
Step-by-Step: How to Restore a UCS on a FIPS-licensed BIG-IP
If you need to modify the UCS:
Extract the UCS file:
mkdir /tmp/ucs_extract
tar -xzvf /var/local/ucs/<yourfile>.ucs -C /tmp/ucs_extract
Make your changes to the configuration files as needed.
Repackage the UCS:
cd /tmp/ucs_extract
tar -czvf /var/local/ucs/<newfile>.ucs *
(Optional) If you want to encrypt the UCS, use the tmsh command below.
To encrypt (or re-encrypt) the UCS:
On the BIG-IP CLI, run:
tmsh save sys ucs /var/local/ucs/<finalfile>.ucs passphrase <your_passphrase>
This will create a UCS file encrypted with your passphrase.
To restore the UCS:
On the target BIG-IP, copy the UCS file to /var/local/ucs/ (or /shared/).
Run the restore command:
tmsh load sys ucs <finalfile>.ucs
If the UCS is encrypted, you’ll be prompted for the passphrase.
If you’re migrating between platforms (e.g., hardware to VE), you may need to use the platform-migrate option:
If you see errors like “Unexpected Error: UCS loading process failed,” ensure the UCS is properly compressed and, if needed, repackage it as a tar.gz and rename it with a .ucs extension before restoring (K13537502).
If you get passphrase errors, double-check that you’re using the same passphrase used during UCS creation.
The simple answer to that one is yes, assuming you want to preserve any protected passphrases from the source, such as AAA objects, Monitor passwords, etc. It is also a must if the restored platform is part of a DSC or a BIG-IP DNS Synchronization Group.
More importantly; migration to a virtual from a physical platform can come with its own challenges. There are various objects within that will not translate over well from one to the other, including the following:
In addition, if you have any DSC features enabled, such as HA Groups, you will need to modify and/or remove them as well if they are currently monitoring objects that exist in the source but DO NOT exist in the target, such as clusters, trunks, etc..
It is entirely possible to be successful, assuming you modify the contents of the UCS prior to your platform-migrate operation. Once I implemented everything above (and some others depending on your situation), I’ve been 100% successful since. Based on what you are migrating, you’ll be able to tell if there’s anything else that needs to be modified as the platform-migrate will typically fail and report it to you in the stdout.
DISCLAIMER: The above statements cover my experiences with the platform-migrate operation when restoring from a UCS sourced from a VIPRION. Your mileage may vary!
