TMSH cron job
i created a TMSH cron job using crontab -e and nothing happens.
crontab -l shows that the cronjob is added to the list.
Help.
What is your requirements?
Could you explain what you mean by “TMSH cron job” ?
If want to run some TMSH commands at regular time periods, here is the procedure.
1) write a shell script to run all the TMSH commands you want to and save it in directory. For example, /var/tmp/script_name.sh
2) Update permissions  to executable one
chmod +x script_name.sh
3) Make a cronjob entry using crontab -e  command
Example:
0 6 1 * * /usr/bin/bash /var/tmp/script_name.sh
Here are the resources which explain more on this::
https://devcentral.f5.com/s/question/0D51T00006aFbGESA0/steps-to-configure-cron-jobs-to-execute-commands-f5-big-ip-ltm-13x
https://devcentral.f5.com/s/question/0D51T00006i7j1A/auto-back-script-in-cron-shell
Regards,
Nag
