TCP::payload replace and MSSQL
Hello,
I’m trying to figure out away to change the database value within a SQL connection string as it passes through the Big-Ip on the way to the DB server.
I’m guessing that I need to do a “TCP::collect” and then search for a specific string (the db name the client is using ) then use “TCP::payload replace” to change it to the Db name I want to use.
Unfortunatly I have no idea how to approach this. Can anyone help? or is there a better way to do this?
Cheers
Simon
There should be some examples already in the forum for doing search/replace within a TCP stream. Try seaching for the keywords you have a hunch would be involved, like: “TCP::payload replace” or “TCP::collect”. I seem to remember something out there that should be fairly close. You should also check the CodeShare and Docs sections as Colin and Joe regularly publish examples there as well.
Hello,
I’ve done some digging around and come up with this (which might be a bit simplistic and optomistic):
when CLIENT_ACCEPTED {
            TCP::collect 300
when CLIENT_DATA {
        if { [TCP::payload] contains "dbafa" } {
           TCP::payload replace 0 0 "master"
           pool SQL-WiP
What I’m really confused with is how to know what he offset and length variables should be for the TCP::payload replace command. I’ve done some packet inspection and the database name seems to be right at the very end of the data.
Can anyone help?
Simon
Simon, if you are trying to modify the TDS stream, you will want to be careful how you rewrite the data as a lot of its fields are length delineated. In another words, there may be offset and length entries that need to be modified along with the field values. I would suggest checking out http://www.freetds.org/tds.htmlexamples for more information on the wire format of TDS.
Hope that helps.
You will likely want to use the “string first” command instead of contains. “string first” will return an index of where the string was matched. You can then use that index in the TCP::payload replace command to replace the correct location.
And as bl0ndie indicated, you may have to replace a little more than just the string.
