switch & swith -globe question
Hello,
I could not manage to work this irule. Please help me to make it run.
Lilly
when CLIENT_DATA {
set pay1 [TCP::payload 8]
binary scan $pay1 IA4 len1 trx1
switch [IP::addr [IP::client_addr]]{
“x.x.x.x/24”{
switch -glob [class match $trx1 ] {
“A”{
do smthng}
“B” {
do something
“C” {
do something
default {
do something
“y.y.y.y/24”{
“D”{
do something
“E” {
do something
“F” {
do something
default {
do something
Hi LillyM,
You cannot switch an IP::addr command the way that you were doing it. See this conversation switch statement, [IP::addr], and varying subnet masks.
The class command (class match $trx1), works with Data Groups. The $trx1, is the variable set in your binary scan. So you can switch off of it, but not perform a class match against it.
Try something like this and let us know if it works for you:
when CLIENT_DATA {
if { [IP::addr [IP::client_addr] equals "x.x.x.x/24" ] } {
switch -glob [ $trx1 ] {
"A" { do something }
"B" { do something }
"C" { do something }
default { do something else }
elseif { [IP::addr [IP::client_addr] equals "y.y.y.y/24" ] } {
"D" { do something }
"E" { do something }
"F" { do something }
Hope this helps!
Hi Micheal,
It gave some error, I am trying to figure them out. If I could, then I will let you know in a few minutes.
Otherwise, I will send you the error and the code that I modified.
Million thanks
Lilly
Hi again Micheal,
I am taking the following error for these lines: " switch -glob [$trx1] {"
[invalid list: list element in quotes followed by “{” instead of space] []
I will appreciate it if you could help on this too..
Lilly
when CLIENT_DATA {
if { [IP::addr [IP::client_addr] equals X.X.X.X/24]}{
“A”{
do something
“B” {
do something
“C” {
do something
default {
do something else
if { [IP::addr [IP::client_addr] equals Y.Y.Y.Y/24]}{
“D”{
do something
“E” {
do something
“F” {
do something
default {
do something else
You should investigate your binary scan command and possibly log the value to your LTM Log to see what you are getting.
TCL Reference Manual: binary
4 character ascii command and no problem in it. It seems to me that it is related with switch -globe command and the error also says like this.
Why do you think it is about binary scan?
Can you post the error that it is logging?
I cannot even load and save this IRULE, I got the following error:
Lilly
You should just need to remove the square braces from the switch string:
when CLIENT_DATA {
switch -glob $trx1 {
Aaron
I would have thought that the square brackets could have caused that problem.
Learn something new all the time.
Can you let us know if Hoolio’s suggestion works?
Hello All,
Firstly I want to thank you for your help and suggestions. In that case (the last one ,Hoolio’s suggestion I meant) I only compare the $trx with some strings A, B,C etc.
But What I really want to do is, comparing with the content of an external file Like "class match $trx1"does.
Is this possible?
Thanks a lot..
Hello Hoolio,
Although this is not the exact equivalent what I want to do, I tried to modified my ırule like this. It is also is not working. I gave the following error:“01070151:3: Rule [IRule error: line 22: [invalid list: list element in quotes followed by “{” instead of space] []”
line 22 => switch -glob $trx1 {
thank you for your help.
Hello,
I read many things in the forums and now I am more confused:)
I want to make my question clear, and waiting for your help as soon as possible. I need to give my irule cpu comparison report today..
Million thanks for your help in advance
---Firstly, I am doing all the following items with IF claues in prod enviroment without any problem but we want to make cpu utilization & and if it is possible we want to use switch clause.
* I have 4- 5 Ip ranges, and I need to decide which external group files will be chose.
* I have many external data group files. They all have many string values inside.
* I need to check $trx1 value, with these string values those inside the external datagroup files
* I could do this with IF statement but it comsumes so much CPU
* Thats why I am trying to using SWITCH clause instead of IF clause
Example:
If ip is in the x.x.x.x/24 ip range
If $trx1 in the A external datagroup file - do something
If $trx1 in the B external datagroup file- do something
If $trx1 in the C external datagroup file- do something
else- do something else
If ip is in the y.y.y.y/24 ip range
If $trx1 in the D external datagroup file - do something
If $trx1 in the E external datagroup file - do something
If $trx1 in the F external datagroup file - do something
else - do something else
else
do something - go to default pool
Hamish replied here:
http://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/2159026/showtab/groupforums/Default.aspx
Aaron
