As you could see, I’ve to duplicate the STREAM::expression for each domain name as I do not know how to insert the $host variable into the replace string.
How could I use a single if statement to get a result like :
The curly braces should prevent expansion of variables and interpretation of meta-characters (Click here). Also, due to a bug, you always ensure that double forward slashes (like those in http://) are enclosed in double quotes. And make sure to escape the periods or I think they’ll be interpreted as a character repeat in a regex fashion:
You could add a check to see if the host value in the request was null and then use the VIP address or the public IP address if the VIP is an internal IP address:
Check if the client used a host header
if {[string length [HTTP::host]}[
set host [HTTP::host]
Use the VIP address instead
set host [IP::local_addr]
mmm… I’m sorry I think and I’m sure I was not clear in my previous post Thank you for your answer aaron, but if I want to re-use this $host variable into the stream replacement ? As you said, I could not use the $host within braces in the stream::expression, so could I do the replacement within the stream_matched event to replace the '/images/blablabla by 'http://media.$host.com/images/blablabla ? Do you have a sample to do that ? Stream::replace ? Thanks
if {[string length [HTTP::host]]}{
when HTTP_RESPONSE {
Check if the response was a 200 and text
if {[HTTP::status] == 200 and [HTTP::header "Content-Type"] contains "text"} {
STREAM::expression "@'/images/@'http://media\.$host\.com/images/@"
STREAM::enable
STREAM::disable
Note that the double quotes allow variable expansion to take place and work around a bug in the LTM code with unquoted //'s.
