hi
this is a bit of a strange question! hopefully it will make sense…
i know there doesn’t appear to be a clean way of dynamically choosing SSL certificates via the same virtual server, so i’m trying to think of an atlernative way of providing SSL without receiving an error. would something like this work?..
- client goes to http://live.com OR https://live.com
- BIG-IP redirects their request to https://TEST.com
- client browser still shows https://live.com in their address bar but the encryption is between the client and https://TEST.com certificate
i guess this is basically masking the URL in the address bar! obviously, if the client was to inspect the certificate it would say test.com and not match what they have in their address bar
i know this sounds a bit crazy, but we have a test department who will be accessing multiple sites behind a single virtual server (because i don’t want to create lots of individual virtual servers etc for testing). they need to test SSL encryption for each of these sites. as it’s for testing, the obvious way is to achieve this is to add a certificate to the virtual server which will simply present an error because the virtual server does not match the web site they typed in their address bar, which the client can ignore because this is only for testing, but it would be nice if i could avoid presenting them with a certificate mismatch error
i hope that made sense
thanks
