SSLDump issues: ERROR: Length mismatch
I am trying to debug some SSL handshake errors and it seems ssldump is different enough on the LTMs to make me a bit nuts. After a few seconds it dies with: ERROR: Length mismatch. The entire interwebs say this is because it needs a ‘-s 0’ command line switch which the F5 version of ssldump doesn’t have. Any ideas how to capture more than a few seconds of traffic?
Check out this article from AskF5: 404 Page not found | BIG-IP Documentation
That is what I was afraid would be the solution as I was trying to avoid the tcpdump then feed into ssldump method. Ah well, seems that is the only option. Thanks!
Hi Bubbagump 12531,
I’m probably about 4 years late to this party but if you’re just tshooting an SSL negotiation issue then running #ssldump -i vlan_100_internal host 10.0.100.41 would give you a continuous feed of SSL negotiation activity to the console for analysis
If wanting to examine within Wireshark then the -s0 flag would be required to allow the ssldump to be ran against the packet capture as it requires the whole packet to be available
