I’ve blogged about Self-signed Server Certificates and how they can cause havoc with client java applications. We’ll I put the call out there to provide solutions and a very slick one has arrived!
XTrustProvider.java:
* The contents of this file are subject to the "END USER LICENSE AGREEMENT FOR F5
* Software Development Kit for iControl"; you may not use this file except in
* compliance with the License. The License is included in the iControl
* Software Development Kit.
* Software distributed under the License is distributed on an "AS IS"
* basis, WITHOUT WARRANTY OF ANY KIND, either express or implied. See
* the License for the specific language governing rights and limitations
* under the License.
* The Original Code is iControl Code and related documentation
* distributed by F5.
* Portions created by F5 are Copyright (C) 1996-2004 F5 Networks
* Inc. All Rights Reserved. iControl (TM) is a registered trademark of
* F5 Networks, Inc.
* Alternatively, the contents of this file may be used under the terms
* of the GNU General Public License (the "GPL"), in which case the
* provisions of GPL are applicable instead of those above. If you wish
* to allow use of your version of this file only under the terms of the
* GPL and not to allow others to use your version of this file under the
* License, indicate your decision by deleting the provisions above and
* replace them with the notice and other provisions required by the GPL.
* If you do not delete the provisions above, a recipient may use your
* version of this file under either the License or the GPL.
import java.security.AccessController;
import java.security.InvalidAlgorithmParameterException;
import java.security.KeyStore;
import java.security.KeyStoreException;
import java.security.PrivilegedAction;
import java.security.Security;
import java.security.cert.X509Certificate;
import javax.net.ssl.ManagerFactoryParameters;
import javax.net.ssl.TrustManager;
import javax.net.ssl.TrustManagerFactorySpi;
import javax.net.ssl.X509TrustManager;
public final class XTrustProvider extends java.security.Provider
private final static String NAME = "XTrustJSSE";
private final static String INFO =
"XTrust JSSE Provider (implements trust factory with truststore validation disabled)";
private final static double VERSION = 1.0D;
public XTrustProvider()
super(NAME, VERSION, INFO);
AccessController.doPrivileged(new PrivilegedAction()
public Object run()
put("TrustManagerFactory." + TrustManagerFactoryImpl.getAlgorithm(),
TrustManagerFactoryImpl.class.getName());
return null;
public static void install()
if(Security.getProvider(NAME) == null)
Security.insertProviderAt(new XTrustProvider(), 2);
Security.setProperty("ssl.TrustManagerFactory.algorithm",
TrustManagerFactoryImpl.getAlgorithm());
public final static class TrustManagerFactoryImpl extends TrustManagerFactorySpi
public TrustManagerFactoryImpl() { }
public static String getAlgorithm() { return "XTrust509"; }
protected void engineInit(KeyStore keystore) throws KeyStoreException { }
protected void engineInit(ManagerFactoryParameters mgrparams)
throws InvalidAlgorithmParameterException
throw new InvalidAlgorithmParameterException(
XTrustProvider.NAME + " does not use ManagerFactoryParameters");
protected TrustManager[] engineGetTrustManagers()
return new TrustManager[] { new X509TrustManager()
public X509Certificate[] getAcceptedIssuers() { return null; }
public void checkClientTrusted(X509Certificate[] certs, String authType) { }
public void checkServerTrusted(X509Certificate[] certs, String authType) { }
Calling Application:
XTrustProvider.install();
This file is up in CodeShare for those who are cut+paste challenged B-).
Hat tip to Exnihilo for posting this solution!
-Joe
[Listening to: Ob-La-Di, Ob-La-Da - The Beatles - The White Album (03:08)]
