Looking for some advice please. We’d like to reverse proxy an internal server via a public ip address.
public VIP has a public certificate issued via a well known CA (client ssl profile) and is listening on port 443, this passes to a pool containing our internal server also on port 443 but this site is using an internal self-signed cert that doesnt match the public cert.
LTM logs show the following when client on the internet tries to connect:
SSL Handshake failed for TCP 1.2.3.4:64681 → 5.6.7.8:443
1.2.3.4:64681 → 5.6.7.8:443: Connection error: ssl_hs_rxhello:10784: alert(70) unsupported version
Do you have any other virtual server assigned the same client-ssl-profile? If so, do you see the similar error on that virtual server? Have you ever tried with another client (browser, mobil etc)?
yes lots of others VS using same profile without issue. works fine in a browser and renders ok, wondering if the self signed and public cert is the cause of the issues?
