LTM SSL handshake failuer (40) with IIS SSL setting Accept
I had an issue that communication from client PC failed with one of pool members. Clinet PC can directly access to the problem member without any issue. If it is accessed through VS, the failure happened.
As investigated with packet capture, following error caused the communication failure.
Transport Layer Security
    TLSv1.2 Record Layer: Alert (Level: Fatal, Description: Handshake Failure)
        Content Type: Alert (21)
        Version: TLS 1.2 (0x0303)
        Length: 26
        Alert Message
            Level: Fatal (2)
            Description: Handshake Failure (40)
As I investigated, I found the problem member’s IIS SSL setting is set as “Accept”. Other working members are set as “Ignore”. As I changed the setting to “Ignore”, the problem was gone.
The IIS SSL setting “Accept” is to accept clinet certificate if it is provided by client. If client did not provide client cetificate, IIS still establish connection. On the VS, SSL server profile is used. the profile setting is almost default.
Do you know why BIG-IP fails the SSL communication if the IIS SSL setting is “Accept”?
have you configured the CA cert of the client certificates in the vserver’s client(side) ssl profile?
How To Configure BIG-IP Part 8 - Client Authentication
We only configure server certificate on SSL client profile. No client cert is set.
Thank you for your reply.
I opened the case with F5 support also. I got following reply. It was indicate the peer-cert-mode on SSL server profile caused the issue when IIS SSL setting is Accept.  But I am not sure why it cause the handshake failure.
# tmsh list /ltm prof.ile server-ssl all-properties
ltm profile server-ssl /Common/XXX_XXX {
    alert-timeout 4294967295
    app-service none
    authenticate once
    authenticate-depth 9
    authenticate-name none
    ca-file none
    cache-size 262144
    cache-timeout 3600
    cert none
    chain none
    cipher-group none
    ciphers DEFAULT:@STRENGTH:!RC4-SHA:!DES:!3DES:!NONE:!SSLv3:!TLSv1
    crl-file none
    defaults-from /Common/serverssl
    description none
    expire-cert-response-control drop
    generic-alert enabled
    handshake-timeout 10
    key none
    mod-ssl-methods disabled
    mode enabled
    options { dont-insert-empty-fragments no-tlsv1.3 }
    partition Common
    passphrase ***scrubbed***
    peer-cert-mode ignore   <<<<==============
    proxy-ssl disabled
    proxy-ssl-passthrough disabled
    renegotiate-period indefinite
    renegotiate-size indefinite
    renegotiation disabled
    retain-certificate true
    secure-renegotiation require-strict
    server-name none
    session-mirroring disabled
    session-ticket disabled
    sni-default false
    sni-require false
    ssl-forward-proxy disabled
    ssl-forward-proxy-bypass disabled
    ssl-sign-hash any
    strict-resume disabled
    unclean-shutdown enabled
    untrusted-cert-response-control drop
