snatpool vs snat
Hi, I have a problem when specifying the snat before passing traffic to another virtual server.
The version using is 9.4.7
As below, I found that option 1 doesn’t work, the source address remains unchanged, but option 2 works fine. Is it a normal behavior?
Thanks.
snatpool snatpool_10.10.10.10 {
members 10.10.10.10
rule iRule_1 {
when CLIENT_ACCEPTED {
snatpool snatpool_10.10.10.10 option 1
snat 10.10.10.10 option 2
virtual vs_2
Really dumb question, but… do you have a SNAT address in the SNAT pool? If you use the snatpool command and a standard pool (instead of the virtual command) does it work?
I’d expect snatpool to work with the virtual command. If it’s not, I’d suggest opening a case with F5.
Also, in your scenario, could you use SNAT on vs_2 instead?
Aaron
