Problem this snippet solves:
Summary: This iRule allows either clear text or TLS encrypted communication with the LTM initiating the encryption process if it sees the appropriate “starttls” command in the SMTP communication.
Code :
when CLIENT_ACCEPTED {
set ehlo 0
SSL::disable
when SERVER_CONNECTED {
TCP::collect
when CLIENT_DATA {
set lcpayload [string tolower [TCP::payload]]
if { $lcpayload starts_with "ehlo" } {
set ehlo 1
serverside { TCP::collect }
TCP::release
TCP::collect
} elseif { $lcpayload starts_with "starttls" } {
TCP::respond "220 Ready to start TLS\r\n"
TCP::payload replace 0 [TCP::payload length] ""
TCP::release
SSL::enable
TCP::release
when SERVER_DATA {
if { $ehlo == 1 and not([string tolower [TCP::payload]] contains "starttls") } {
TCP::payload replace 0 0 "250-STARTTLS\r\n"
TCP::release
clientside { TCP::collect }
