I found reference to https://f5cloudsolutions.slack.com/, but I can’t just log in to it -- looks like it might require an invitation. Is this a public Slack workspace?
Hi cbarlock,
Yes, it’s public slackware. Try access with this invitation link : Create Account
Regards
Thank you! I’m in.
For reference for anyone stumbling upon this post, that Slack channel is specific to the F5 Automation Toolchain products.
Some guidance from the AS Github repo: https://github.com/F5Networks/f5-appsvcs-extension
Community Help
We encourage you to use our Slack channel for discussion and assistance on AS3 templates (click the f5-appsvcs-extension channel). There are F5 employees who are members of this community who typically monitor the channel Monday-Friday 9-5 PST and will offer best-effort assistance. This slack channel community support should not be considered a substitute for F5 Technical Support. See the Slack Channel Statement for guidelines on using this channel.
Hello colleagues,
Could someone send me an invitation link to join this slack channel ? Really appreciate.
Thank you,
Felix
Hi Felix,
sure , https://join.slack.com/t/f5cloudsolutions/shared_invite/zt-2jubn5ms6-uCg5NoQSglXB~meVaW5d~g
Regards
Hello,
Can someone provide a current invite link? I’d like to join for follow a few channels. Thanks in advance.
Hi Javilo,
Sure here is the invite link : https://join.slack.com/t/f5cloudsolutions/shared\_invite/zt-2mvdoihzm-PPXVsAlKe\_cF217X\_Lunag
Hi.
Can you provide me with an invitation to?
Regards,
-Ulf
sure !
f5cloudsolutions slack
Hello,
I want to join the slack channel as well.
Thanks!
So is it a public channel or not? Why is it so difficult to sign up then? All the invitation links here are no longer valid, looks like they expire pretty soon.
tl;dr: I would like to get an invitation link for https://f5cloudsolutions.slack.com, too. Thx!
Re "that Slack channel is specific to the F5 Automation Toolchain products’, citing f5cloudsolutions.herokuapp.com ,
Fwiw, GitHub - F5Networks/k8s-bigip-ctlr: Repository for F5 Container Ingress Services for Kubernetes & OpenShift. · GitHub mentions “the cis-kubernetes channel in our https://f5cloudsolutions.slack.com/” for getting help from the community. That would be the channel I’m interested in, but looks like it’s not easy to get in…
