SIP SDP::field manipulation
Can the SDP::field phone_number be removed or replaced or is this simply a get value command?
I’m not aware that command exists; I can’t find it on the wiki. The SIP::header command would seem to be the one you are after and could be used to remove and then re-add the To: header.
The command can be used to get or replace the value but not remove the field.
"SDP::field field-name "
