Simple pool selection using URI not so simple...
Greetings once again, I am trying to select a pool based on content in the URI; what I am seeing is the first request selects the pool correctly, but requests that follow are using the default pool.
VS with cookie insert persistence
default pool defined in the VS resource
rule looks like this
 if { [HTTP::uri] contains "en_CA" } {
use pool pool_cananda
   log local0. "Canada request - canada pool"
else { use pool pool_us  }
   log local0. "using default pool"
here are some log entries
Sep 25 12:13:39 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
Sep 25 12:17:46 tmm tmm[1055]: Rule rule_test-can_redirect : Canada request - canada pool
Sep 25 12:17:46 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
Sep 25 12:17:50 tmm tmm[1055]: Rule rule_test-can_redirect : Canada request - canada pool
Sep 25 12:17:50 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
Sep 25 12:17:57 tmm tmm[1055]: Rule rule_test-can_redirect : Canada request - canada pool
Sep 25 12:17:57 tmm tmm[1055]: Rule rule_test-can_redirect : using default pool
What am I missing?
-L
Can anyone provide some insight on this? I’m still stuck.
-L
Here’s the code you gave, reformatted a bit:
  else {
    use pool pool_us
I think it’s just your logging that’s off. Notice that your “using default pool” log is outside the else statement, so it will display that every time. Try this:
  else {
    use pool pool_us
and see if it changes.
we can mark this one in the “DOOHH” category; it turns out that I had another rule that I use to trasfert HTTP to HTTPS and in that rule, there was an 'else pool pool_us" statement. This was causing the traffic to be sent to the US pool, once I removed it, it redirects correctly.
Thanks for the eyes on this, guess I just need to slow down.
-L
