Any one create an iRule to perform - Signed Header Authentication ?
Basically the F5 would need to decrypt/validate received HTTP header(s) that are encrypted with a private key (shared between the F5 and the CDN)
Are they encrypted or signed or both? Encryption and authentication are very different things, cryptographically speaking. What algorithm(s) would you want to be using?
There are a few cryptographic primitives available from iRules now. For authentication, people have definitely used them to do HMAC computation.
Hi Christopher,
What is the encryption based on? Is it based on MD5 or CRC?
Bhattman
This would be Akamai’s g2o authentication used for CDN
The F5 will receive from Akamai edge servers a pair of headers. One in plain text with some data fields (time in epoch format, unique id, …) and another with a base64 encoded signature. The signature is a hash (md5) of some of the data fields in the first header and a pre-shared secret.
Well, iRules has base64 and md5 commands, so that should be possible based on that information. I can’t find any specific specs from Akamai, though, so I can’t guarantee it.
Judging by the code at https://github.com/refractalize/nginx\_mod\_akamai\_g2o/blob/master/ngx\_http\_akamai\_g2o\_module.c (an NGINX module for supporting g2o), it looks like a fairly straightforward HMAC using a shared key, expressed in base64. This should be doable in iRules just fine.
Nice find Joel and that did help - the iRule is being tested - thanks
Hello:
I was wondering if you can share the iRule that you were working on.
Thanks in advance
Luke
Hello,
I am working on it with but I can’t do it work propertly, I was wondering as weel if you could share the iRule that you was working.
Many Thanks in advance ![]()
I needed a rule to validate G2O headers so I wrote the below rule and I’ve also submitted it to codeshare.
Code
Requires TMOS 11.1 or above for support for "CRYPTO::sign"
This code block detects if the Akamai authentication headers are there
if so it then does the caculations based on the shared secret
finally it compares the output and logs a match
if {[HTTP::header exists "X-Akamai-G2O-Auth-Data"] && [HTTP::header exists "X-Akamai-G2O-Auth-Sign"]} {
set shared secret here
set secret_key "pass"
set data "[HTTP::header value "X-Akamai-G2O-Auth-Data"][HTTP::path]"
set signature "[HTTP::header value "X-Akamai-G2O-Auth-Sign"]"
set signed_data [b64encode [CRYPTO::sign -alg hmac-md5 -key $secret_key $data]]
if { $signed_data eq $signature } {
log local0. "Signatures match"
