Sideband send data limitation
I’m experiencing a TMM core dump on the Sideband send command when I’m trying to send data of 32MB+ Is there a limitation on the amount of data that can be send through the sideband ? Thanx
Hi Cassie,
There’s no hardcoded limits to the amount of data that can be transmitted over a sideband connection. This might be through the way you’re irule is configured along with a specific bug on the version you are running on.
Is it possible for you to post anonymized copy of the irule? The community could probably help with the code. Otherwise I would look towards F5 support to see if you are running into a bug with your iRule.
-=Bhattman=-
Hi Bhattman,
Thanks for you answer, I suspect a bug on our version and will go to f5 support.
Cassie
