Set Manual Cookie Peristence
I’m trying to implement an iRule from wiki article at:
https://devcentral.f5.com/wiki/irul…tence.ashx
I am pretty new at iRules and I’m missing something, so I apologize in advance for my ignorance.
I have the following setup:
Virtual Server vs_MyTwoServers
Default Pool Pool_MyTwoServers
Persistence Profile mySiteCookie Parent profile: cookie Cookie Method: Http Cookie Insert Cookie Name: PersistCookie8hrs
Nodes: 10.6.0.68:80 (Server7910) 10.6.0.68:80 (Server7911)
I want to be able to add a uri query of and have that session traffic only go to Server7910
I’ve setup a data group list called my_forced_nodes:
Data Group List Name: my_forced_nodes
Type: String
String Records:
7910 := 10.6.0.68 80
7911 := 10.6.0.69 80
iRule from wiki article with my information in it:
when RULE_INIT {
set cookie_name “my_node_forced”
Get node id from URL ending in ?node=server1, ?node=server2, etc.
set node_forced [findstr [HTTP::uri] “?node=” 6]
Or from previous cookie
set has_cookie [HTTP::cookie exists $::cookie_name]
if { $node_forced eq “” and $has_cookie } {
set node_forced [HTTP::cookie value $::cookie_name]
Map node id to IP and port found in a class
Entries should be strings of the form
if { $node_forced ne “” } {
set node_data [findclass $node_forced $::my_forced_nodes " "]
if { $node_data ne “” } {
set node_ip [getfield $node_data " " 1]
set node_port [getfield $node_data " " 2]
pool Pool_MyTwoServers member $node_ip $node_port
set node_forced “”
when HTTP_RESPONSE {
Add a cookie to continue forcing node assignment
HTTP::cookie insert name $::cookie_name value $node_forced path “/”
elseif { $has_cookie } {
Delete cookie and resume load balancing (with built-in persistence)
HTTP::cookie insert name $::cookie_name value “” path “/”
HTTP::cookie expires $::cookie_name 0 absolute
Updated for v10/11 with minor changes:
when RULE_INIT {
set static::cookie_name "my_node_forced"
set node_forced [findstr [HTTP::query] "node=" 5]
set has_cookie [HTTP::cookie exists $static::cookie_name]
 If node_forced (from query) isn't there but cookie exists - set node_forced = cookie value
if { $node_forced eq "" and $has_cookie } {
set node_forced [HTTP::cookie value $static::cookie_name]
 If node_forced (from query) is there but cookie is not - set cookie flag
if { $node_forced ne "" and !$has_cookie } {
set do_cookie 1
if { $node_forced ne "" } {
set node_data [class match -value $node_forced equals my_forced_nodes]
if { $node_data ne "" } {
pool local-pool member $node_ip $node_port
if { [info exists do_cookie] } {
unset do_cookie
HTTP::cookie insert name $static::cookie_name value $node_forced path "/"
Thanks Kevin!! It appears to be consistently working.
Appreciate your help!
Hank
Add on to this question:
Can you dynamically build a data group list by querying a pool for a list of nodes? For instance in the example above, can an iRule determine the number of servers in the pool and assign a numeric value to the node member? Then instead of using uri query of node=7910, it could be node=1?
What I’m trying to get at is, can the iRule be generic that it would work for any VIP/Pool to be enable app owners to test each individual node without having to create a data group list and an iRule for each application.
Thanks,
Hank
Here’s a minor modification of the above using a dynamically created list on CLIENT_ACCEPTED:
when RULE_INIT {
when CLIENT_ACCEPTED {
 create simple pool member list
set my_nodes [members -list local-pool]
set do_cookie 1
set node_data [lindex $my_nodes $node_forced]
unset do_cookie
Essentially the same as before, but this time a list is created dynamically of all of the pool members (set my_nodes [members -list local-pool]). Use set my_nodes [active_members -list local-pool] to get a list of only the available nodes. Then later just read that list entry to get the desired node (set node_data [lindex $my_nodes $node_forced]).
An alternative method would be to modify the data group via shell script and TMSH commands on some specified interval. Create an external monitor that polls the pool members, rewrites the data group, then updates it in the config. Add this monitor to a “phantom pool” - a pool not tied to a virtual server. This method allows you to create a scheduled job that is backed up as part of the config.
