Sensitive Cookie Missing 'HTTPONLY' Attribute
We were recently dingged by an audit scan for “Sensitive Cookie Missing ‘HTTPONLY’ Attribute” not being set on several of our websites, which pretty much is spread accross several different VS in the LTM.
I’d like to create an iRule to set this attribute, however everything in the forums I’ve found doesn’t seem to be for my version of the LTM, 10.2.3. We can’t upgrade to 11.x because our device doesn’t support it so I was hoping someone could help me with the iRule.
Any suggestion would be greatly appreciative.
Thanks,
Bob
Hi Bob,
If you can’t upgrade to 11.x to use the ‘HTTP::cookie httponly $cookiename enable’ command, you could loop through the Set-Cookie headers and insert the httponly property:
Aaron
Hoolio…I checked out the link and it seems to be doing more than what I’m looking to do, so I attempted to strip it down a bit.. I came up with the following code, which seem to work ok, it came up as a vaild iRule
when HTTP_RESPONSE {
   set ck [HTTP::header values "Set-Cookie"]
   HTTP::header remove "Set-Cookie"
   foreach acookie $ck {
         HTTP::header insert "Set-Cookie" "${acookie}; HttpOnly"
[\code]
I didn't do the Curl command before running this so to double check it was applying I ran it afterwards and was given this:
[root@LTM1:Active] config  curl -I http://test.domain.com
HTTP/1.1 200 OK
Date: Fri, 02 Nov 2012 14:14:26 GMT
Server: Microsoft-IIS/6.0
Cache-Control: post-check=3600,pre-check=43200
X-Powered-By: ASP.NET
Cache-Control: no-cache
Pragma: no-cache
Expires: -1
Content-Type: text/html; charset=utf-8
Content-Length: 14971
Set-Cookie: ASP.NET_SessionId=qrjevsr5lk14uw45b1d4ghql; path=/; HttpOnly; HttpOnly
Since it's showing it twice indicates, at least to me, that the HTTPOnly is already being applied.  So I did a curl on another site that the irule wasn't being applied to but was listed in security scan results as a site that didn't have the HTTPOnly.. The results are below..
[root@LTM1:Active] config  curl -I http://domain.com
HTTP/1.1 200 OK
Date: Fri, 02 Nov 2012 14:22:29 GMT
X-AspNet-Version: 2.0.50727
Set-Cookie: ASP.NET_SessionId=m3u2q2rppvieexfm3o4mlwz4; path=/; HttpOnly
Pragma: no-cache
Expires: -1
Content-Length: 18883
Based on what I'm seeing this is may be a false Positive, right?
Thanks,
Bob
Based on what I’m seeing this is may be a false Positive, right?doesn’t audit have log to prove what they found?
anyway, to prevent adding duplicate httponly, you may check whether there is before adding.
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.79:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b pool foo list
pool foo {
   members 200.200.200.101:80 {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
      if { [string tolower $acookie] contains "httponly" } {
         HTTP::header insert "Set-Cookie" "${acookie}"
[root@ve10:Active] config  curl -I http://200.200.200.101
HTTP/1.1 200 OK
Date: Fri, 02 Nov 2012 14:54:25 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sat, 27 Oct 2012 03:22:35 GMT
ETag: "4183f3-59-f28f94c0"
Accept-Ranges: bytes
Content-Length: 89
Set-Cookie: foo1=123456; path=/; HttpOnly
Set-Cookie: foo2=abcdef; path=/
Content-Type: text/html; charset=UTF-8
[root@ve10:Active] config  curl -I http://172.28.19.79
HTTP/1.1 200 OK
Date: Fri, 02 Nov 2012 14:54:30 GMT
Content-Length: 89
Set-Cookie: foo2=abcdef; path=/; HttpOnly
Thanks!! I did find that the audit was running the scan against the URL so it caused it to return a 302 redirect response
and the redirect response was where the HTTPOnly attribrute was missing from. With the addition of the if/else clause this resloved the problem.
Thanks again,
Bob
