Self Ip's displaying in AV 1x1 call when callee ip address is expected.
Using BIG-IP to load balance IBM Sametime works well except when I plug in Bandwidth Manager into the AV solution. Using self ips as part of our F5 solution means that to route a call I need to add the self ip addresses into my Bandwidth configuration so the calls will route. With this config in place when trying a 1X1 call, the call policy from one ip to another isn’t being applied.The callee’s ip address being displayed is always the F5’s self ip address. How can I get the actual ip address of the callee to display correctly?
