A few days ago, I had to perform a security update and observed a discrepancy in the synchronization of security policies between the two high-availability (HA) devices. To illustrate, a security policy that appeared transparent on the active device was found to be blocking when the standby device took over. The disparity extended beyond just the enforcement mode; even the rules differed, resulting in the unintended blocking of legitimate traffic.
I mention that “Application Security Synchronization” is enable for the device group.
@buzzkiller you could follow this up as hereunder and let me know if it is fixed or not.
1- make sure to create a new device group “sync-only”, you could create it sync automatically or manually
2- then assign it under Security ›› Options : Application Security : Synchronization : Application Security Synchronization
3-and repeat applying sync on it.4- After making sure syncing with that approach, try again to set WAF sync back to “datasync-global-dg” not your created sync-only group. → it would be resolved
