ASM attack signatures not syncing between active and standby F5
Hello F5ers,
I have a pair of f5s in active/standby setup running ASM (WAF) module. I have ASM synchronization setup with sync-failover device group on both f5s. Everything else works fine but I noticed ASM signatures under system > software management > live update page no longer shows any signatures downloaded or installed my standby f5 anymore. when i try to select an option for “Installation of automatically downloaded updates” such as Real time or scheduled then click Save, I get a “failed to save configuration” error.
This db variable value is same on both f5s
tmsh list /sys db liveupdate.allowautoinstallonsecondary value
sys db liveupdate.allowautoinstallonsecondary {
value “false”
Standby f5:
cat /var/log/tomcat/liveupdate.log | egrep ‘isMaster|isAsmMaster|isDatasyncMaster’
2026-06-17 16:20:51 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-17 16:20:51 INFO SyncHandler:351 - Set isMaster = true
2026-06-17 16:20:51 INFO SyncHandler:347 - Set isDatasyncMaster = false
2026-06-17 17:18:46 INFO SyncHandler:351 - Set isMaster = true
2026-06-17 17:18:46 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-17 17:18:46 INFO SyncHandler:347 - Set isDatasyncMaster = false
2026-06-23 15:10:23 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-23 15:10:23 INFO SyncHandler:351 - Set isMaster = true
2026-06-23 15:26:03 INFO SyncHandler:351 - Set isMaster = true
2026-06-23 15:26:03 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-23 15:26:03 INFO SyncHandler:347 - Set isDatasyncMaster = false
2026-06-23 15:41:11 INFO SyncHandler:351 - Set isMaster = false
2026-06-23 15:41:11 INFO SyncHandler:343 - Set isAsmMaster = false
2026-06-23 15:41:11 INFO SyncHandler:347 - Set isDatasyncMaster = false
Active F5:
2026-06-17 16:39:29 INFO SyncHandler:347 - Set isDatasyncMaster = true
2026-06-23 15:36:50 INFO SyncHandler:343 - Set isAsmMaster = true
2026-06-23 15:36:50 INFO SyncHandler:351 - Set isMaster = true
Did anyone came across this issue in their environment?
version: 17.1.3
platform: VM
Appreciate any help! thanks
Hi P_K,
I’ve encountered a few issues related to the ASU sync problem.
Newly added and updated article:
ASM Automatic Signature Update (ASU) Fails to Sync to Standby Unit After Upgrade
myF5
Bugs identified in a case opened to the support:
Live Update configuration sync failure in HA setup
Bug ID 2219081
“Live Update” API is unresponsive after upgrade and recover only after tomcat restart
Bug ID 2152445
tmsh restart sys service tomcat
Often helps
