Score bonus & failover condition
Hello guys,
A question regarding the behavior of the failover in the 11.4.1
Two devices, in active/standby, with a trunk
Active unit bonus score : +10
Bonus per available trunk interface : +10
Initial setup (F5A active):
F5A : 20 (2 int) + 10 (active) = 30
F5B : 20 (2 int) + 0 = 20
With 1 interface shut on F5A :
F5A : 10 (1 int) + 10 (active) = 20
=> F5A still active, ok.
With 2 interfaces shut on F5A :
F5A : 0 (0 int) + 10 (active) = 10
=> failover on F5B.
With 2 interfaces OK on F5A :
F5A : 20 (2 int) + 0 = 20
F5B : 20 (2 int) + 10 (active) = 30
=> F5B still active, ok.
Until now, everything is logic.
With 1 interface shut on F5B
F5B : 10 (1 int) + 10 (active) = 20
=> Failover on F5A !
I don’t understand why we have a failover event in this last case. Any explanation ?
We use a trunk with 2 interfaces and this is what we ended up doing. We don’t need the 2nd 10 gig interface active so we only have 1 interface up per trunk and this is working ok.
The weight we assigned was 60 and we have 2 interfaces so each interface has to be up to get a weight of 60, with 1 interfaces down the weight is 30 and on the active unit you add the active bonus making the total 55 on the primary as shown here and the highest score becomes active.
LTM1:Eval:Active:In Sync] config tmsh show sys ha-group HA1 Sys::HA Group: HA1
State enabled Active Bonus 25 Score 55
On the standby it looks like this
(LTM2)(cfg-sync In Sync)(Eval:Standby)(/Common)(tmos) show sys ha-group all Sys::HA Group: HA1
State enabled Active Bonus 25 Score 30
Consider when you activate the 2nd interface in the trunk. Now the full weight of 60 is added to the active bonus of 25 so that would be a score of 85 and the standby would be 60. If you lose 1 of the 2 trunk interfaces on the active the score changes to 25 + 30 or 55 which is lower than the standbys 60 so a single interface failure out of 2 in this configuration would trigger a failover. Consider how you want this to work fail over from 1 interface or both? So when we do activate the 2nd 10g interface we could increase the bonus to 35 so the one interface weight of 30 + active bonus 35 (65) would still be higher than the standby which is at 60.
Thanks for your answer. This is indeed a way to avoid this situation.
But here I’m trying to understand why we have this behavior (failover or not in case of equality of the score). It looks like it is link to the management IP for the decision…
Yes, it uses the management IP to break a tie
Sorry to bump an old thread. I’m curious to know how the management IP is used as a “tie breaker”? is there a SOL that details this?
i understand when ha-group score is equal, ha score (not ha-group score) is used to break tie.
Manual Chapter: Managing Failover
your management ip in F5A is higher than the one in F5B.
Time to resurrect this thread one year on. I have observed this behaviour also (highest management IP used to break a tie) but I am yet to see this mentioned in any documentation.
Would be great if someone could post a link (it’s not in the Manual chapter: Managing Failover, as posted below).
Dylan, it is in the link posted by nitass, here is the extract.
About matching device utilization values In rare cases, the BIG-IP system might calculate that two or more devices in a device group have the same lowest device utilization score. In this case, the BIG-IP system needs an additional method for choosing the next-active device for an active traffic group.
The way that the BIG-IP system chooses the next-active device when device utilization scores match is by determining the management IP address of each matching device and then calculating a score based on the highest management IP address of those devices.
For example, if Bigip_A has an IP address of 192.168.20.11 and Bigip_B has an IP address of 192.168.20.12, and their utilization scores match, the BIG-IP system calculates a score based on the address 192.168.20.12.
