BIGIP is acting SP to an IDP. This IDP is one of our authentication methods to the Webtop.
For instance, if you are logging out with the Logout-button from the webtop a samlrequest is sent to thier SLS, the ticket is destroyed at thier end, but bigip is throwing an error: “Internal error. Failed to process SAML request/response. Please try again or contact your system administrator if error persists.”
With uri: /vdesk/my.acl.php3?errorcode=8001
The response is getting back successful from the IDP (as issuer) to Destination=“https://<bigipadress>/saml/sp/profile/post/sls” with a succes code:
Seems like the IDP didnt understood “ResponseLocation”. The Reponse was sent to Location rather than ResponseLocation, this is something BIGIP does default:
we are develping own SAML Solution and F5 Acting as IDP here. we not have format of SLO request from SP to IDP, we getting error in F5 Deflate error, not sure it is any encrypted , we
want SLO Request from SP to IDP format, no Sign, no encryption format !
we are using below format and it is getting error . it is send from SP to IDP(F5)
We would lilke to start a pilot, but this is a blocking issue at the moment.
I have also tried setting the logout URL in Azure AD to https://VPNbox/saml/sp/profile/post/slr directly, but that also gives me the redirect to the /vdesk/my.acl.php3?errorcode=8001 URI.
Was a while ago but there was alot of issues with “reposts” with 307, when it comes to SAML.
I would suggest that you manipulate the metadata from your bigip-SP connector and then reimport it into Azure AD. simply remove SLS. and remove the resoponder attribute and Place the slr after location,
Also make sure that you are using the right binding, Edit SAML SP Connector > SLO Service Settings > Single Logout Binding: POST (if you’re using post).
I did already set the Logout Url in the Azure AD app registration to : https:/vpnbox/saml/sp/profile/post/slr, but that also redirected me to vdesk/my.acl.php3?errorcode=8001.
I have now done as you said: modified the XML and uploaded and I only see the Logout URL change, so I expect it’s the same as what I did when manually changing the Logout URL in Azure AD.
Have you kept HTTP-redirect binding in the metadata? try to remove that and only keep HTTP-Post.
Because as the APM log indicates, Azure sends it as a GET/Redirect (look at the traffic with chrome + f12 and preferly with a saml-trace tool) and not a POST. You can also try to change that manually from Azure, using POST as a reponse instead of Redirect (if that is possible).
If the only solution is to use redirect, then only provide http-redirect as a binding in your metadata from big-ip, and change the location to /saml/sp/profile/redirect/slr
I cannot modify that in Azure and indeed, it does a GET instead of a POST. Azure documentation says: ‘This URL is used to send the SAML Logout response back to the application.’
