Hi All,
Wondering is there any IF NOT function in 4.5.x irules? example,
if not http_uri ends_with “/”
used pool pool1
else
discard
or is that any other method we can used to achieve the similar output.
Thank
Hi All,
used pool pool1
else
discard
Thank
If you were wondering where your previous post went, it didn’t disappear - I moved it to the iRules v4.x forum. iControl is our management programming interface and your question was about iRules. Someone from our 4.x team should respond over there.
-Joe
Check out the iRules v4.x forum for the response.
-Joe
