Hi All,
Wondering is there any IF NOT function in 4.5.x irules? example,
if not http_uri ends_with “/”
used pool pool1
else
discard
Thank
Hi All,
used pool pool1
else
discard
Thank
In v4.x, we support the following logical operators (from the 4.6.2 Reference Guide):
Logical operators
Logical operators modify an expression or connect two expressions together to form a logical expression. Arguments to logical operators must return a value of true. Table 5.7 lists the logical operators and their meanings.
The logical operators
Logical Operators --> Meanings
not --> Is the value returned by the expression not true?
and --> Are the values returned by both expressions true?
or --> Is the value returned by either expression true?
So the answer is: yes!
-Joe
