Is it possible to use iRule to route traffic to one pool when there is a file upload and other HTTP traffic to a default pool?
Hi WTW,
Is it possible to use iRule…
Everything is possible with iRules… ![]()
To develop a tailordered iRule for your Web Application, you have to find out how the upload functionality is implemented. Some Web Application are using a HTTP-POST request targeting a specific file (e.g.
./upload.php
) to upload the data and some others Web Applications are using the HTTP-PUT request (e.g. Webdav Clients).
Depending on your Web Application an iRule may look like this:
Example 1:
if { [string tolower [HTTP::path]] ends_with "upload.php" } then {
pool upload_pool
pool default_pool
Example 2:
if { [HTTP::method] equals "PUT" } then {
pool upload_pool
pool default_pool
Cheers, Kai
