RMS DMS Configuration Installation Issue
We are currently trying to impliment the F5 MP 2.0 in our environment. We are setup with two RMS Servers running in a cluster with 2 seperate management servers. I installed the MP on the two RMS servers without a problem but when I go to install the MP on the 2 standalone management servers I get an error about the Service account where at the end it complains that the SDK service is not running. The SDK service should not be running on the stand alone management servers. Am I missing something about this? Any insight?
Daven
When you enter the user name to be validated in Setup, it looks up the correct SDK server (which I’m guessing is the RMS Cluster) and then tries to connect to it and make sure the user entered is privileged enough to run the F5 Service (Ops Mgr Admin). You can try a couple of things. First, just open up a SCOM Powershell console and make sure it can connect and start up successfully. If it does, you can check a specific registry key value:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft Operations Manager\3.0\Machine Settings\DefaultSDKServiceMachine
The value should target the Cluster name, not a specific node in the RMS cluster. If it DOES target the cluster name, check the SDK service in your Cluster Configuration and make sure it’s registered as a clustered resource. If everything there looks good, let us know and we will go from there.
Thanks,
Dave
Great to hear! Let us know if anything comes up and we will help you in any way we can.
Thanks,
Dave
