I would like to restrict a subnet (192.168.1.0/24) from accessing VIP: 10.10.10.10. Is this possible with a irule? I can only find ways on how to restrict traffic from a single IP and not a subnet. Any help would be appreciated.
Dan
Dan
use this:
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr]/24 equals 192.168.1.0] } {
drop
Just go with a datagroup with Irule method. So that you can add more IP’s in the blacklist group on the file. You need not keep editing your irule.
Create a datagroup called blacklist subnet, make sure its type IP.
type: ip
ltm data-group internal blacklist_subnet {
records {
20.20.20.0/32 { }
30.30.30.30/25 { }
type ip
Then create your irule like below,
if { [class match [IP::client_addr] eq blacklist_subnet] } {
log local0. "Client IP - [IP::client_addr] is blacklisted. Dropped traffic"
drop
Thanks I got it figured out with the data groups. Your example was command line instead of GUI so it threw me off. Thanks again for your help!
