Restrict NTP deamon
Hello there,
How do i restrict access to the NTP deamon from being accessed by other devices on ipv4 and ipv6.
Regarding this arcticle you can supply a tmsh command what disable access on ipv6 level, how do i also restrict ipv4 access? 404 Page not found | BIG-IP Documentation
tmsh modify sys ntp restrict replace-all-with { “::1” { address ::1 no-modify enabled no-trap enabled } }
Best Regards,
Frans van Dokkumburg
Frans,
You can either use the port-lockdown on the self-ip to completely block ntp or you can use the ‘tmsh modify ntp’ commands to create restrictions.
-Chad
